Another 6.0 sucker - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-21-2013, 02:42 PM Thread Starter
denarm's Avatar
Another 6.0 sucker
Please help, 2004 F250 SD crew 4x4 in the last 8 months I have had the EGR bypass done and replaced the injectors and last month the FICM, it ran great, I did an oil change, filter, and fuel filters I also removed the lower filter/pump housing and cleaned it, ran great for a few weeks, but I was smelling coolant but did not see a leak and did not run hot. I stopped at the store and this time had to add 1 gallon of coolant, and found a small crack in top of radiator, I guess from laying on it to work on it, added the coolant and the rotten thing wouldn't start, turn over but wouldn't run, it acted just like it did with bad FICM so towed it home FICM checked good, so I gave it a few shots of starter fluid and it started and ran great, drove around awhile came back and turned it off and it cranked back up, so I let it set for a while and it wouldn't run, so I replaced the fuel pump, and still the same, will start with starter fluid and run as long as you want but after it sets about 10 minutes or so it want start with out using starter fluid, it seems like it looses its prime. Could this be the FPR at upper filter.
denarm is offline
post #2 of 9 Old 06-22-2013, 06:44 AM
It is a possibility. You really need some live data while cranking to know for shure if it's anything else.
By useing starting fluid you bypassed the normal start sequence but apparently the HPOP and system is working enough and was able to keep the truck running.
You now need to determin what wasn't working at initial crank attempt.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 9 Old 06-22-2013, 07:16 AM
What were your cranking rpm? Sounds like a possible weak starter, or weak batteries.
2006 White F350 CCLB 2WD
dowmace is offline
post #4 of 9 Old 06-22-2013, 09:22 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Sounds like the HPOP...
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 9 Old 06-22-2013, 09:26 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 956 Post(s)
Feedback Score: 6 reviews
You need to hook it up to a good scanner and see if the IPR and ICP are in range.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 9 Old 06-22-2013, 04:39 PM Thread Starter
denarm's Avatar
New batteries and turns over fast. Today I removed the upper fuel filter and turned the key and let the bowl fill with fuel and then turned it off, and after about 10 minutes the bowl was empty again and I see no leaks.
denarm is offline
post #7 of 9 Old 06-22-2013, 04:43 PM Thread Starter
denarm's Avatar
By the way I am new here and I hope I am doing things properly, and thanks for all the help.
denarm is offline
post #8 of 9 Old 06-22-2013, 05:47 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
This ^^^ and....
That^^
Please
You could save the life of a sick child
NYC F-350 is offline
post #9 of 9 Old 06-24-2013, 06:19 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
I've seen weird problems like this when using an aftermarket fuel filter. Since you just changed those, it could be your problem. If you didn't use a genuine Ford fuel filter, change it and see if that takes care of the problem.
AshevilleEngine.com is offline
Tags
fuel pressure regulator , fuel pump , no start
