FICM has 0 volts - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-20-2013, 08:27 AM Thread Starter
FICM has 0 volts
Just bought this truck a week or so ago and seemed to run fine until I went to start it the other morning. No start at all turns over but will not start.
Batteries and Alt were replaced prior to me getting it along with a list of other things, so I thought I would check out some stuff before I have it towed checked fuses everything fine, did test FICM and it shows 0 volts I called the guys at BulletProof (very helpfull) he said to check a relay on the left fender I had one to swap out with it no change and still no volts at the FICM, Batteries show 12.4 volts each, any suggestions would be great trying to avoid towing in if possible I have an appointment set next week to have the oil cooler and egr delete installed and would like to drive it in.
skidoo88 is offline
post #2 of 9 Old 06-20-2013, 08:29 AM Thread Starter
Need to say this is a 03 with 140,000 if that helps
skidoo88 is offline
post #3 of 9 Old 06-20-2013, 09:54 AM
Snake's Avatar
Quoted: 46 Post(s)
All plugs and connections look ok?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #4 of 9 Old 06-20-2013, 10:33 AM
ZMANN's Avatar
Quoted: 1464 Post(s)
no volts like no input volts or output volts or both ??
We Miss you Ronnie
ZMANN is offline
post #5 of 9 Old 06-20-2013, 11:17 AM Thread Starter
Yes as far as I can tried to trace down wires looking for any rubbing etc and nothing jumped out at me
skidoo88 is offline
post #6 of 9 Old 06-20-2013, 11:19 AM Thread Starter
I'm guessing the pin test is for output volts, I guess I would need to find out were the feed to the FICM is to see if there is power to it.
skidoo88 is offline
post #7 of 9 Old 06-20-2013, 04:12 PM
backhoebill's Avatar
Quoted: 335 Post(s)
Send a message via Yahoo to backhoebill
It's possible that one of the connectors may not be seated good on the bottom of the FICM. They are kind of difficult to get at, but you may have bounced one out while driving, especially if the locking clip is broken.
HTML Code:
'06 F250 4x4, 251,xxx hard miles, IPR egr delete and coolant filter, blue spring, billet wheel, 4" turbo back, Atlas 40, SCT Livewire, Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is online now
post #8 of 9 Old 06-20-2013, 04:22 PM
ZMANN's Avatar
yes it is the output
I thought you may be looking at a pid
We Miss you Ronnie
ZMANN is offline
post #9 of 9 Old 06-21-2013, 04:25 AM
dxusmc's Avatar
check connectors..when the FICM is installed, the harness closest to the front of the truck is the power supply/ECU harness. It's also the bigger of the 3. If it is clipped in, I'm not sure how to really test if its getting voltage without some sort of continuity light. IE: I don't know which pins you could probe with a multimeter.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
