Long exteded crank p0671-p0678 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-19-2013, 05:07 PM Thread Starter
Mathes's Avatar
Hello, just did bdp egr cooler and factory oil cooler, bdp ficm, blue spring mod, 6.4 banjo bolts, serviced the turbo, changed coolant over to cat-1, replaced fuel filters, now I have a long long crank time and have every glow plug circuit code except 5 and 7. The harness from the pass battery I assume with fuseable links has been cut open and is taped back together(like that when I go the truck) Any help would be great, I did this all to make it reliable and now have problems when I didn't before... little aggravating I'm at 2k and counting!!
03 build in progress
Mathes is offline
post #2 of 2 Old 06-19-2013, 07:07 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Most likely the glow module or the harness causing the issue. Glow plugs are very dependable.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
