IPR 4 ICP leaking oil - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-19-2013, 03:04 PM Thread Starter
chris-rector's Avatar
hey guys stupid question I replace my HP OP and my IP are an ICP drove it around drove around for about a week and also didn't I started getting drops of oil now when I start it now oil pours out of it from one of the sensors I was wondering if I should put teflon tape around the threads of the ICP an IPR valve
<a href="http://truckprofile.com/members/chris-rector/Ford-F350-2003/694">My Truck Profile</a>
chris-rector is offline
post #2 of 6 Old 06-19-2013, 05:29 PM
jtaylor75's Avatar
no. just check the orings on the ipc and the ipr. Make sure the sensor isnt busted.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 6 Old 06-19-2013, 05:39 PM Thread Starter
Both are brand new o'rings are in good shape the covers in good shape I'm at a loss
post #4 of 6 Old 06-19-2013, 05:47 PM
jtaylor75's Avatar
Then there has to be something else going on. Regardless, I wouldn't put any teflon tape on your IPR and IPC threads.
06 CCSB FX4 Lariat
Next:
A fuel system
post #5 of 6 Old 06-19-2013, 06:01 PM
Quoted: 725 Post(s)
Replace the O-rings. Don't reuse them. There may be a small nic in it that you can't see, but 3000psi will surely find it.
BTW, get viton not buna.
Corey@CNCFAB is online now
post #6 of 6 Old 06-19-2013, 06:04 PM Thread Starter
Yeah I just went down and got all new o'rings and washers everything for the truck so tomorrow more for tomorrow down to the o-rings for the HPOP
