Fuel Leak.... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-19-2013, 01:54 PM Thread Starter
shenanigans
junior125's Avatar
Quoted: 1574 Post(s)
Garage
Fuel Leak....
As soon as my truck cools down I'll be getting underneath it to tighten the 6mm plug on the backside of my cylinder head as it is leaking fuel again... This is the second time in a month, is there anything that I can do to keep it from doing this again?
Mike
2005 CCSB F250 4X4
junior125 is offline
post #2 of 3 Old 03-21-2015, 11:11 AM
mtpolarbear's Avatar
did you ever find a solution for this? I just did the heads and studs and it looks like I have the same thing on the back of the drivers side head. I swear I tightened it!
POLARBEAR - 2003 F-250 SD CC SB FX4, 6.0, 3:73 gears, EGR & Cooler Delete, Bulletproof Oil Cooler, ARP Studs, A.R.E. Topper, Bedrug, Zoodad, 5" Magnaflow turbo back, K & N cold air intake, coolant filter, EDGE INSIGHT CTS, SCT X3 Tuned by Vivian, Energy Suspension Master Bushing kit, RiffRaff Boots, Blue Spring, 6.4 Banjo's, Fumoto Oil Valve, Fumoto water drain plug, Whistler 2000 Watt Inverter, DC Power 200amp Alt. Rebuilt FICM w/Atlas 40, Riff Raff Boots and counting.
mtpolarbear is offline
post #3 of 3 Old 03-21-2015, 07:38 PM
Bocephus80's Avatar
Replace the O-ring
2007 F250 C.C. L.B. 4x4
Blue Spring, Scangauge II, Riff Raff boots,
XDP coolant filter
Bocephus80 is offline
