P0113 trouble code - IAT Sensor - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-19-2013, 12:08 PM Thread Starter
Question P0113 trouble code - IAT Sensor
Can anyone tell me where this sensor is located? My engine light has recently come on and am getting a trouble code of P0113 Intake Air Temperature Curcuit High Input. I've been doing some research on the internet, trying to figure out what to do. From what I've found, I need to check this sensor to ensure it's not "gummed" up on the inside and also check the wiring going to it. Problem is I can not find anywhere on the internet to tell me where it's at.
2005 F250 6.0 Turbo Diesel
104,000miles
2WD - Long Bed
pkgronzo is offline
post #2 of 8 Old 06-19-2013, 12:47 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Screwed into the intake manifold. Grey plastic sensor.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 8 Old 06-19-2013, 01:50 PM
p0113 is for iat sensor loctated in airbox tube behid air filter, if it equipped with a mass air flow sensor it is built into maf sensor
dieseltech11 is offline
post #4 of 8 Old 06-19-2013, 01:53 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
Damn...my apologies to the OP. I didn't look up the code to see which IAT sensor throws that code. My bad.
Please
post #5 of 8 Old 06-19-2013, 03:15 PM Thread Starter
Forgive me, as I'm new to diesel, and working on engine things in general. But I'm tired of throwing my money away on simple things I can do myself, if I new how to do.
How do I know if it is equipped with a mass air flow sensor? I will do some internet research right now on "maf" sensor and see what I can find.
Do you agree that I'm on the right track of pulling this sensor to see if it's 'gummed' up, and possibly replacing it?
Am I hurting anything by driving it, before I get it figured out?
Thank you!
pkgronzo is offline
post #6 of 8 Old 06-20-2013, 12:32 PM
You are not hurting it by driving it, you can look in the air intake tube and if there is a flat five wire connector plugged into a sensor than that is your maf, if there is a two wire sensor there then it just has iat with no maf.
post #7 of 8 Old 06-27-2013, 07:59 AM Thread Starter
Thanks you for your help. Is there a way to test or have the MAF / IAT sensor tested? I'd hate to spend the $100 bucks on a new one to have the engine light stay on with the P0113 code? I pulled it out last night and it didn't look real dirty or "gummed" up. Attached is what I pulled out and looked at last night. I'm pretty sure I'm looking at the right thing.
pkgronzo is offline
post #8 of 8 Old 06-27-2013, 08:47 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
There is MAF cleaner available; don't use brake cleaner. But the indication you are getting is more indicative of a failure or a shorted wire. Try an auto recycler.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
Tags
iat , p0113
