2005 F-250 Hot start problem! HELP! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-18-2013, 08:14 PM Thread Starter
Angry 2005 F-250 Hot start problem! HELP!
My Truck will start when cold. until it warms up hot it will misfire a bit (been doing for a while now) I've used hot shots secret stiction eliminator & has helped. but now it wont start hot.
Code: ICP pressure too low, Engine cranking
Had a similar problem month ago & it was a o-ring around injector blown out. but I didn't have a code like I do now.
once it fires up it will run until shut off.
Any suggestions?
I have already booked an apt with my awesome mechanic for July 4th
But if I can narrow down the problem what to try before then... ex. Sensors
Thanks to anyone who would be able to give their input!
Braden.
Powerstroke 16 is offline
post #2 of 3 Old 06-18-2013, 08:49 PM
jtaylor75's Avatar
Do an air leak test. But i would suspect the STC fitting.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 3 Old 06-18-2013, 09:06 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
You have a hpo oil leak. May be another o-ring not sure if you have a stc fitting or not with 2005 but it is the hpo causing the problem.
If you have gauges take a look at the % value of the ipr. The higher the % the more the valve is closing trying to build pressure. At idle you should see around 21% anything above 30% is no doubt a hpo leak according to Fords diagnostic values.
A ScanGaugeII is a good tool for looking at all the values.
There is a slim chance the icp has a issue when hot but again slim. You can try unplugging the icp which is on the pass valve cover and see if it will start when hot next time.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
Tags
6.0 , hpop , icp , injector , oil
