F-550 low IPR and desired ICP - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-18-2013, 07:37 PM Thread Starter
Hey. I have a late 2004 F550 picker truck. Stock, 6 speed, starts well but makes low power. According to my NexIQ scan tool at WOT pulling or empty it tops out at ICP 3.xx volts, IPR 60%, 2600 psi desired and actual. I changed oil, filters (all), cleaned EGR, EBP and tube, swapped in known good ICP sensor, passed aired up HPO system test, FICM volts bang on, IPR pulled and clean and cycles, batteries new and load test ok, fuel in good shape, turbo sounds just like my 05 F350, only leap of faith is clear exhaust pipes. Putting off cutting into that, it has no cat and is mostly straight pipe save a straight thru muffler. Olny code is P1000. Have cleared some related to a previous no start. Also has a Ford box to control PTO operation. Makes no difference on or off. Power balance test is ok too. I am baffled. Seems like the truck only asks for half the fuel it should. It seems to get it too but a two ton that gets outrun and out pulled by my old gm 6.5 is no truck at all. Any ideas besides throwing parts at it? I don't do that....
sask3500 is offline
post #2 of 18 Old 06-18-2013, 08:55 PM
jtaylor75's Avatar
If you do the air test and take the oil filter out can you hear a gargling noise? If so then you might have a HPOP on its way out. Do you have any way to monitor boost levels?
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 18 Old 06-18-2013, 09:07 PM Thread Starter
Nope. No stock boost gauge. I will run the gurgling oil filter housing test in the AM. My main curiosity is why the ICP desired and actual match the IPR duty cycle. If the pump was on the way out wouldn't the computer ask for near 85% to hit less than 3900 psi or whatever normal max ICP is?? 60% of 3900psi is aboot 25-2600 psi. Seems like the truck says "you want me to pull that?! F@#&* you." And gives half the fuel it should.
sask3500 is offline
post #4 of 18 Old 06-18-2013, 09:27 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
That is a good question, can the throttle pedal not be giving 100% input!! I am pretty sure the ScanGauge will look at the values.. I think
Take a look there if it checks out maybe the pump is the issue ? I have seen my truck in the 4100+ range a few times but not for some time.
2600 is pretty low, what are your values at idle icp/ipr ?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 18 Old 06-18-2013, 09:41 PM Thread Starter
About 26-30% @ idle, lower once warm, maybe 25%. 560ish psi maybe 600 at the high end when warming up. Throttle input matches what my foot is doing. Actual ICP follows desired very close, fast as you can glance between the two numbers. And fuel pump pressure was 57 psi. Never hooked it up for a full throttle run to see if fuel pressure falls on it's face.
sask3500 is offline
post #6 of 18 Old 06-18-2013, 09:51 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It is quite possible this cab/chassis is using a detuned PCM. However, you need to check the AP for full movement. It is possible that a floor mat is preventing full movement.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 18 Old 06-19-2013, 06:46 AM Thread Starter
In my mind that seems unlikely. Why would anyone want a half power truck? Rev and speed limiters, yes. If a Ford employee can chime in here, that would be ideal.
I would like to be pointed to some information on the 2004 programming and what mat cause the computers to cut or limit power. Or confirmation that C&C's could be had with low output PCMs.
sask3500 is offline
post #8 of 18 Old 06-19-2013, 08:14 AM
What is your fuel pressure at WOT?
dieseltech11 is offline
post #9 of 18 Old 06-19-2013, 03:12 PM Thread Starter
I will check it but again it's the IPR ICP numbers that get me. The fuel supply is mechanically regulated and looks like a fuel shortage shouldn't have a digital feedback. It would only show up as a loss of power with the icp and ipr showing near max at full load. I don't remember seeing a fuel pressure sensor. Mass fuel seems to be calculated rather than measured,right? Also my fuel pulse width says 0.00 but cmp and ckp are synced.
sask3500 is offline
post #10 of 18 Old 06-19-2013, 09:16 PM Thread Starter
Any more ideas? Sorry to keep hitting the same subject over and over but there has to be an answer here somewhere.
sask3500 is offline
