Oil Cooler is leaking, but still need help with...... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-17-2013, 04:43 PM Thread Starter
Ok folks. 2003 6.0 111,000 miles. I tow 8 to 9k lbs travel trailer about once a month.
Symtoms: 1) Difficult to start...sometimes...Turns over but sometimes seems to be searching for a starting position.
2) If I don't let it warm up (minimum 5 minutes) it runs like hell. Bucks and kicks and has no power with a definite drag on the turbo. After warm up, it runs like a champ. Have to keep block heater plugged in if less than 60 degrees or has to warm up more than 10 minutes.
3) Last tow in May, turbo exhaust line popped off and lost all power on interstate. Once at campground, was able to reattach the pipe and and good to go.
4) Oil and other goo is found in the coolant reservoir tank. (leaking oil cooler)
What has been done so far------
1) Ford replaced the EGR cooler about 3 years ago, but I am not seeing exactly the same symptoms from it.
2) All diagnostics show zero active or stored codes, but it can't be true.
3) Ran 2 bottles of sea foam through to see if it would clean the injectors. No improvement.
What I know
1) Catalytic converter is clean
2) Doesn't white smoke.
3) Only puffs a little black smoke when I get on it, or towing up hill and get on it.
4) Filter are clean
5) Turbo sounds good?!?!!
6) New EGR valve and EGR is dry carbon (no wet goo in the EGR, or at least as much as I can see at the valve hole.)
SOOOOO....with all that said, is all of that the result of the leaking oil cooler, or what else to look at/investigate?
Plan someday soon to work on oil cooler, but should I just buy the heat exchanger and some gaskets, or replace with aftermarket such as bulletproof? While I'm in there, what to do with the EGR?
Sorry for all of the words, but I need all the help I can get.
Thanks
kab716 is offline
post #2 of 5 Old 06-17-2013, 07:07 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
FICM should be checked as well as your glow plug circuit. Definitely sounds like a failing FICM or injector issues.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 5 Old 06-18-2013, 04:07 AM
jtaylor75's Avatar
hey man im down in snellville if you want me to take a look at it for you.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #4 of 5 Old 06-18-2013, 05:37 AM Thread Starter
I am wanting to do the work myself to continue to learn about my current truck and future trucks. But is there a way to know which FICM to buy without digging in? I would like to have one on hand when I get into it, so I can be done in a day. I just don't have a lot of time or $$. I also understand that the 7 pin has to be purchased as a hole unit, and I would have to have it preprogrammed. Any suggestions on where to buy? Thanks.
kab716 is offline
post #5 of 5 Old 06-18-2013, 06:05 AM
jtaylor75's Avatar
if the FICM volts are low, you can just have it rebuilt. A lot of people on here like Ed at FICMrepair.com The only down side is your out of a FICM for a few days.
06 CCSB FX4 Lariat
Next:
A fuel system
