A different deltas question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-17-2013, 02:15 PM Thread Starter
Will a "sick" engine trying to compensate run a hotter oil temp? Did egr delete and oil cooler replacement 30,000 ago with mutiple restore flushes and a coolant filter install. Deltas were in range until dveloped an exhaust leak on up pipe, where deltas went to 18-20 under normal driving. Fixed exhaust leak and immediately developed a pressure leak in intake tube between intercooler and manifold and deltas are still up. So again, will a "sick" engine compensating for under power generate higher deltas? Thanks in advance for any input and info.
illfixxit is offline
post #2 of 4 Old 06-18-2013, 05:11 AM
jtaylor75's Avatar
thats a though one. Did you do the restore before or after the oil cooler replacement. IF you did them after the oil cooler replacement then too me it just sounds like a clogged oil cooler
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 4 Old 06-18-2013, 06:37 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Yes, but a slight increase. Think of it like towing a load, it may increase a small amount. If your deltas have widened a lot, you are suffering the follow-on from your initial flush and treatment. Compared to others, you did well for it to make it another 30k.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is online now
post #4 of 4 Old 06-18-2013, 06:45 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
Deltas were in range until developed an exhaust leak on up pipe, where deltas went to 18-20 under normal driving.
EOT usually creeps up when an oil cooler is clogging from what I have seen
to have it jump is strange
what are your temps ?
We Miss you Ronnie
ZMANN is online now
