Help!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-16-2013, 06:00 PM Thread Starter
Help!!!
Ok finally got the truck put back together today after do head gaskets and the thing starts blowing fuel out of the valve cover vent on the drivers side. I put all new o-rings and copper washers on the injectors so now I'm at a loss
2004 6.0 arp head studs
tgarner16 is offline
post #2 of 5 Old 06-16-2013, 06:04 PM
BlackSheep5's Avatar
Did you make sure the old copper washers came out when you pulled the injectors?
Sent from AutoGuide.com App
08 F250 6.4L FX4
BlackSheep5 is offline
post #3 of 5 Old 06-16-2013, 06:08 PM Thread Starter
Yes the old coppers all were still on the injectors when I pulled them out
Could it be the injector cups
post #4 of 5 Old 06-16-2013, 07:32 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Did you clean out the hold-down holes before you torqued down the injectors? It sounds like one of the o-rings failed or the injector is not seated or broken.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 5 Old 06-16-2013, 08:04 PM Thread Starter
Yes everything was cleaned at the machine shop but I am thinking that the o-ring must have failed
