More truck problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-14-2013, 09:27 AM Thread Starter
331stroker's Avatar
More truck problems
Well I finally figured out what was going on with my no start issue and then I was about 2 hours away from home it died going down the highway.
Truck will crank and fire but thats it. I get P0231 p2614 p2617 codes and from what I read they would be secondary fuel pump circuit is low, cam sensor, and crankshaft position sensor.
I'm lost at this point and in need of urgent help. I seen some guys say FICM but my FICM has always shown strong voltage and I've also seen some say its a wiring issue from those sensors into the computer, some sort of chaffing.
Please help! I need my truck on the road!
2006 F-250 XLT
Lariat Swap
6" Rough Country on 35's
5" TB w/ 7" dump, Matt's SRL XX tune (LOVE IT!), Powermaxx, EGR Delete, Banjo's, Fuel Spring upgrade
Awaiting Installation: ARP headstuds
more to come!
331stroker is offline
post #2 of 6 Old 06-14-2013, 09:52 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Forget about the crank/cam sensors for now. Those two codes pop up after continual long cranks all the time. Also, most of the wire chafe issues were earlier models than the '06 year. Not saying it isn't possible..
Try swapping the fuel pump relay with a known good one for starters.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 6 Old 06-14-2013, 09:54 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Ok i couldnt resist!!! LOL jk
Sent from AutoGuide.com App
2000-7.3L is offline
post #4 of 6 Old 06-14-2013, 10:27 AM Thread Starter
331stroker's Avatar
Well I've got an airdog2 on it, should I try putting it back to stock? Seems like I've had problems ever since I put it on.
2006 F-250 XLT
Lariat Swap
more to come!
post #5 of 6 Old 06-14-2013, 10:41 AM
NYC F-350's Avatar
Quoted: 51 Post(s)
Check your wiring. That code points to an electrical issue somewhere. No idea how your airdog2 would cause that code other than electrical connection/bad relay.
Please
post #6 of 6 Old 06-14-2013, 11:55 AM Thread Starter
331stroker's Avatar
I'pl check all of my wiring for the airdog.
2006 F-250 XLT
Lariat Swap
more to come!
