03 F350 won't start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-14-2013, 05:12 AM Thread Starter
03 F350 won't start
I have 03 6.0 It was hard to start one morning but once it started ran fine. I pulled trailer with it and started four or give times that day fired rite up after the first time. The next day I couldn't get it to start at all. I hocked up my scan tool and had no RPMs when it was turning, so I replace the crack sensor. Now I RPMs but still won't start. Any ideas ?
03F3502 is offline
post #2 of 9 Old 06-14-2013, 05:27 AM
dxusmc's Avatar
what type of scan tool do you have? Can you read ICP (injector control pressure) and IPR (injector pressure regulator) valve? What voltage does your Fuel Injector Control Module have? How are the batteries? Also what trouble codes is the scanner picking up..that would help narrow it down a bit
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 9 Old 06-14-2013, 08:52 AM Thread Starter
I have an spx tech force 2. ICP IS 1,578. Couldn't find opt valve. ficm volts is logic 12.48 main 47.42. Batterys seem going not very old turn truck over good. Code came up this time is P0603 icm kam malfunction. Wasn't in there last time I looked. Thanks for the help
03F3502 is offline
post #4 of 9 Old 06-14-2013, 09:07 AM
dxusmc's Avatar
icm kam malfunction..I've seen that on mine before..but go to read it again, and its gone. Other than that everything sounds good, batteries look strong just from the ficm logic reading. I had a no start issue before when my cps went out, I know you just replaced the crank sensor, so possibly they went out together. Don't know how likely that is though.
Are you getting FICM/PCM Sync?
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #5 of 9 Old 06-14-2013, 09:19 AM Thread Starter
Ya I got sysnc. I have a cam sensor I'll go ahead and put it in.
03F3502 is offline
post #6 of 9 Old 06-15-2013, 08:24 AM
don't believe it's your cam sensor....sounds like you may have an o-ring in the top of the injector bad or an o-ring some where in the hpop system bad.how does the ficm sound slow click or fast.if it's fast most of the time good but if it's slow there's your problem.
i had a truck yesterday do this and would not fire but would off of ether.i do not recommend this if you've never used it.but i have used it many times and it has saved me a bunch.if it starts then you know it's not the cam sensor.
you can crank the truck over for periods of time where you will get a false reading also.
fatbastardf350 is offline
post #7 of 9 Old 06-15-2013, 03:24 PM Thread Starter
Do need to turn it over for click or just key on ? I noticed yesterday that my scan tool showed rpm now ,but doesn't show crank time when your turn it over and the rev per cinder is zero.
03F3502 is offline
post #8 of 9 Old 06-15-2013, 08:10 PM
it makes a buzzing noise with key on if your not hearing this then you have found your problem most likely.report back on what you fined.
post #9 of 9 Old 06-17-2013, 07:51 AM Thread Starter
It buzzes for about 30 seconds than nothing.
03F3502 is offline
