High ect/eot deltas plus low Coolant temp. Help - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-12-2013, 07:06 PM Thread Starter
theblacknight's Avatar
Hey all. I have an 04 6.0 with 117k on it. It has an egr delete and sinister coolant filtration kit and hpop was done at 109k. No noticeable drivability problems except for a weak start sometimes where i have to hold the key to crank extra or it putters off. My Eot is around 225 degrees warmed up and cruising with my matco scanner on it while my ECt never gets above 150 degrees. Am I looking at a stuck open thermostat? Also if that is the case once I replace I'm assuming 235 degrees is a little hotter than the. Engine will be running and most likely out of the 15 degree delta range so would you all suggest I flush the coolant and change the oil cooler?
2001 F350 CC SB 7.3L. Sold Miss it
2004 F350 6.0 111k ccsb lariat 8 inch lift 38x15.5x20 toyo open countrys, cold air intake, 4 inch DP 4 inch straight pipe to 6 inch tip, sct tuner flashpaq, Sinister EGR Delete, Sinister coolant Filter system in box(waiting on free time)
theblacknight is offline
post #2 of 10 Old 06-12-2013, 07:37 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Yup looks like a new thermostat for sure. I would do the best flush possible before changing the cooler. Then get a coolant filter on their and cross your fingers. And heck depending on how energetic your feeling might look into a water pump change if your still running the oem.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 10 Old 06-12-2013, 08:02 PM
Look at the ECT and EOT in the morning when cold. Make sure they read the same. Could be a bad ECT sender.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #4 of 10 Old 06-12-2013, 08:08 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
cross your fingers for a bad EOT sensors. If its good more than likely your going to be doing a oil cooler change in the near future. Your oil shouldn't ever get that hot, especially when your coolant is that cool.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 10 Old 06-12-2013, 08:10 PM
information regurgitator
NYC F-350's Avatar
Quoted: 53 Post(s)
Double check the EOT and ECT readings on a COLD engine. See if they are within a few degrees after a good long cold soak. If they aren't you may have a bad temp sender.
Next, if those are in acceptable ranges, change the thermostat..then recheck the delta.
Get the truck up to standard operating temp (ECT in the high 180's low 190's). Find a long flat section of road where you can keep it between 55-65 MPH for a few miles. Keep an eye on the temps.
If the EOT exceeds the EOT by 15F, it is time for a new oil cooler.
(It seems I need to learn how to type faster.. 2 posts in the time it took me to type this out..)
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 10 Old 06-12-2013, 08:27 PM
asian195's Avatar
Quoted: 2 Post(s)
Haha, I do that all the time...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #7 of 10 Old 06-13-2013, 04:56 AM
Hahah.... Thats why I don't type much... guy would have bought a new truck by time I was done...
Good to see you back on the forum NYC.
MikeB
PSDMikeB is offline
post #8 of 10 Old 06-13-2013, 03:14 PM Thread Starter
Ok truck sat 12 hours today while I was at work. I started it up with my Matco determinator scanner on it and went into the data stream to look at the readings. What's weird is that there are two listings for engine oil temp degrees under my data stream. 1 says its like -6980 degrees and the other listing for engine oil temp degrees seemed like it was the one that had the right reading. So looking at the second engine oil temp listing and the engine coolant temp listing they were within 2 degrees of each other until 144 degrees where the engine coolant temp stopped in its tracks and stayed there and engine oil temp climbed to 200 degrees along my 20 minute highway cruise. Thoughts? Thoughts about the 2 different engine oil temp listings under my data stream and the one oil temp degrees listing with the wacky reading?
post #9 of 10 Old 06-13-2013, 04:16 PM
RetiredFD's Avatar
Switch the sensors and retest
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #10 of 10 Old 06-13-2013, 05:03 PM
PHYRMN's Avatar
^^^Agreed.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
