Stolen Truck! Now had #5 Contribution code. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-12-2013, 10:18 AM Thread Starter
About 6 weeks ago my 04 F250 was stolen from my drive way. 12 hours later it was found sunk to axles in the mud about 7 miles from my house. After I locked the manual hubs I was able to drive the truck right out of the mud.
I had the truck inspected, the locks, ignition, rear view mirror and a cup holder needed to be replaced. I had the work done and noticed a hard start cold problem that I had not ever had before and a slip in the trans when cold (Not to mention lost 4MPG). We found that the alternator was bad and replaced it thinking it would fix both cold problems...it did fix the hard start but the trans continued to slip. I had the the truck checked again and the tech said the fluid looked as if it needed to be flushed. When he had checked it 1000 miles before at the last oil change he had said it looked fine. The shop recommend that the trans be replaced.
The insurance company insisted on a second opinion...agents my wishes the truck was taken to the dealer. The dealer check the trans via a computer and found nothing wrong, they did however find a problem with injector #5. They said it was giving a contribution code. The dealer said that this problem with the #5 injector is what I am feeling when I feel the slip. I disagree.
If it is an injector problem....how could it being stolen cause this? Not to mention the alternator? I had not had any of these problems before it was stolen. I don't want to get stuck with the bill. Help!
WADieselChick is offline
post #2 of 6 Old 06-12-2013, 11:05 AM
Texas Proud
charlie.thomas's Avatar
Not being a bearer of bad news but when my alternator went out I lost an injector shortly after. Loss of voltage to the FICM will cause problems if it doesn't get fixed. Alternator is cheap and easy to do on your own and injectors aren't bad. I haven't had any luck with ford dealers, I'd recommend taking it to a reputable diesel shop close to you. But that's my opinion, j/s. Good luck and keep it rolling!
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #3 of 6 Old 06-12-2013, 11:06 AM
Texas Proud
And I forgot to mention, a bad alternator will show contribution codes on the injectors as well.
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #4 of 6 Old 06-12-2013, 03:02 PM
JustinOOO9's Avatar
Quoted: 472 Post(s)
Garage
do you have any gauges to check FICM voltage, trans temp other then the stock dash cluster?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #5 of 6 Old 06-13-2013, 06:58 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
It probably happened cause they drove it like they stole it instead of driving it like some Ol'Lady. Just kidding! You got lucky, I bought a new truck in 2003 and it was stolen with 1,200 miles on it. They found it the same night in a creek but it was upside down.
AshevilleEngine.com is offline
post #6 of 6 Old 06-13-2013, 08:27 PM
HarvestingInternationally's Avatar
^ wow that sucks
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
