6.0 died will not start back need help diagnosing - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-12-2013, 04:50 AM Thread Starter
Chaas312's Avatar
truck has been running great since head stud, head gasket, egr delete and few other mods a few months ago untill yesterday drove to work not problems went to gander mtn after truck fired up like normal pulled out of the parking lot about 100 yds and it just died turns over but will not fire checked ficm and have 47v pulled injector plug and will not read anything will hit on a shot of start fluid oil press comes up to normal on dash anyone seen this before power on ficm but not out is that a common problem? checked all the fuses and there good any help would be greatly apprichated
Chaas312 is offline
post #2 of 3 Old 06-15-2013, 07:16 PM
sounds like you had trash pass thru your ipr.if you don't have ae then take ipr out
and look at it visually and see if there is a hole in the screen if replace ipr.i will bet this is the culprit.
fatbastardf350 is offline
post #3 of 3 Old 08-23-2013, 05:31 PM Thread Starter
Chaas312's Avatar
Haven't been on in a while but I replaced the stc fitting and ipr and she's been running strong since, thanks for the help
Sent from AutoGuide.com App
Chaas312 is offline
