6.0 starting problem - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-11-2013, 10:35 PM Thread Starter
I recently bought a 6.0 with 60k miles on it. The guy that previously owned it had custom tunes put on a sct and has egr delete, studs, and powermax turbo but has trouble starting after sitting cool for about 6 hours.
Long crank like a cold start and when it does eventually start it has a rough idle for a few minutes. I unplugged the ICP and it didnt change anything. Heating the block by plugging it in made it start a lot quicker but it still was a gradual start with a rough idle for some time after. Any suggestions?
qwoots is offline
post #2 of 11 Old 06-11-2013, 10:40 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
It could be the oil. My buddy had this same problem and when it came time for him to change his oil I was there and he was putting 1 gallon of Lucas with the rest being 15w-40. That oil is so thick when cold, I'm surprised the oil made it into the injectors.
Can you monitor your ipr?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 11 Old 06-11-2013, 10:50 PM Thread Starter
Aight I'm going to replace it tomorrow morning and I'll see if it fixes it, just glad to hear its not a freak problem since I'm new to these engines
And no I wouldnt be able to moniter IPR's, should I or just wait to see if the oil change fixes it?
qwoots is offline
post #4 of 11 Old 06-11-2013, 10:54 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Rotella T6 my friend, it'll run so smoooth and start so easy. After sending in oil samples to BlackStone, I'm on my 3rd change with a sample and I'm running this one to 10k miles. Another member is running 15k miles on the rotella per BlackStone analysis. I'll never touch Lucas! Just ask Ramonpowerstroker and the sludge under his valve cover from Lucas
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #5 of 11 Old 06-11-2013, 10:55 PM
Quoted: 8 Post(s)
I use T5, but it gets cold where I'm at...
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 11 Old 06-11-2013, 10:57 PM
Quoted: 8 Post(s)
Hopefully it's not your HPOP, but since it starts good warm it doesn't seem likely.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 11 Old 06-11-2013, 11:03 PM
SuperDutyCoalBurner's Avatar
FICM???? buddy had similar problem with his 06
~2007 F250 Harley Davidson Edition~
8inch Fabtech lift stuffed with 37's, Sinister Intake Elbow, Sinister Coolant filter package, H&S intake, Edge Juice W/ Attitude Platinum w/ EGT Sensor, 5inch Turbo straight piped back, BD Diesel CAC Boots, Custom interior sound done by the experts at
~KINGS BAY TRUCKS~
SuperDutyCoalBurner is offline
post #8 of 11 Old 06-11-2013, 11:03 PM Thread Starter
Thanks for the help, I'll post results and which I used
And yeah it starts better bet still not a solid start and a rougher-than-normal idle for a while, I'm hoping its not HPOP either haha
qwoots is offline
post #9 of 11 Old 06-12-2013, 02:06 AM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
sounds alot like stiction....google archoil.... the stuff flat out works!
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #10 of 11 Old 06-15-2013, 08:21 PM
i could have not said it any better.
fatbastardf350 is offline
