Weak Starter???? also CAI ? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-11-2013, 08:19 PM Thread Starter
OK, so Ive been having random long cranks, and Ive ruled out HPO. I'm posting a screen of the graph of RPM and Voltage during cranking. I'm trying to rule out Cam sensor and Crank sensor, so Im hoping this will help to rule out a weak starter. It sounds ok cranking it over. Bottom is seconds, left side is RPM. Thick line is the RPM reading and the thin line above is Voltage but it doesn't show it on the graph, the voltage drops to a low of 10.2 so Im thinking new batteries might be something to look at.
Also, the CAI the prev. owner installed is just, well I don't even know how to say it but it doesn't work well. the filter gets hot. but the ambient temp was 103 deg, and letting it idle the IAT was 148. my ? is is this that bad, if so, how bad is it affecting mileage/ power?
Name:	RPM cranking.jpg
ajfrac is offline
post #2 of 3 Old 06-13-2013, 08:59 PM Thread Starter
Bump.
ajfrac is offline
post #3 of 3 Old 06-13-2013, 10:51 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 548 Post(s)
Garage
I cant tell what your rpm is by the chart.
But the minimum rpm is: 100rpm's, again (the minimum) should be well above 150
FICM voltage minimum is: 8 volts.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
