thumpin noise in air filter - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-11-2013, 03:18 PM Thread Starter
country6.0's Avatar
Hey guys and gals! Im in need of a second opinion. My 2006 KR started making a thumpin noise today, truck runs good, performs good but the thumping seems to flow out of my air filter, dosent get louder with throttle, so im thinking i need to check my valves what do you guys think, i dont want to pelace this engine, its original 6.0 with 136000 egr delete sct chip afe cooler tubes, volant ram air system, any advice would be awsome.
country 6.0
2006 F350 king ranch egr delete,staight pipe,sct tuner, volant cold air kit,blue spring update,edge cs,
country6.0 is offline
post #2 of 10 Old 06-11-2013, 03:25 PM
taskforcefreddy's Avatar
It's not turbo fart, is it?
taskforcefreddy is offline
post #3 of 10 Old 06-11-2013, 03:29 PM Thread Starter
country6.0's Avatar
Nope, i was just out side with it and i almost think i feel air coming back through my air filter tube.
country 6.0
post #4 of 10 Old 06-11-2013, 05:09 PM Thread Starter
country6.0's Avatar
bump, anyone ever delt with this noise
country 6.0
post #5 of 10 Old 06-15-2013, 07:05 AM Thread Starter
country6.0's Avatar
So I tore into the valve covers, removed my oil rails and found no damage visable, should i pull the heads or just assume the noise is due to my parinoia
country 6.0
post #6 of 10 Old 06-15-2013, 09:45 AM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
it could be your paranoia especially considering you're running an aftermarket intake setup. The stock intake is very good at keeping engine sounds down.
I notice econolines which have a different kind of intake than an F-series make a slight thumping at idle
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 10 Old 06-15-2013, 10:21 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 580 Post(s)
Garage
I would put the OEM Donaldson air filter back on it.
It is the best filter for the 6.0 PERIOD, and sinner6.0L is correct about intake db's being lower and intake more stable.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is online now
post #8 of 10 Old 06-15-2013, 04:31 PM
Louiediesel's Avatar
I have and OEM filter and it does the same, nothing to worry about !!! is a 6.0.......
Louiediesel is offline
post #9 of 10 Old 06-16-2013, 07:48 AM Thread Starter
country6.0's Avatar
hey thanks guys im gunna throw the oem unit back on it i love this truck just dont wanna get stranded on my trip to california
country 6.0
post #10 of 10 Old 06-16-2013, 10:44 AM
thumping
In my experience the thumping noise in the intake is an exhaust valve not opening and the pressure from the cylinder firing is going out the intake valve when it opens causing the noise. My truck was doing this and found a bad lifter and wiped out camshaft.
jpott62 is offline
