EGR/Fan Sensor/Circ Error? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-09-2013, 09:11 PM Thread Starter
Had some kind of animal get up in my engine and when I started my truck it got shredded. Checked the fan and everything for damage but it all looked fine. Drove for several days, then all the sudden my check engine light came on randomly with the following 3 codes when I scanned it.
P0401 Exhaust Recirculation Insuff Detected
P0480 Cooling Fan 1 CTRL Circ Error
P0528 Fan Speed Sens Circ No Signal
Do I have an EGR problem? Fan problem? Both? Any idea where I should start? Thanks For the help. I have a 2004 F250 6.0L 4x4. Thank you Again for your help
Jafruech is offline
post #2 of 6 Old 06-09-2013, 09:24 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Sounds like it either chewed the wires up for the fan clutch and EGR valve or when it got ate by the fan it broke some wires.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 6 Old 06-11-2013, 02:00 PM Thread Starter
So I looked at it and pulled on the wire assembly that runs into the top back of the fan (pictures attached). I'm good with the mechanical side, but I don't know much about the electrical side. What is this wire assembly called, and where can I get a replacement? Thank you again.
ID:	123338   Click image for larger version
Jafruech is offline
post #4 of 6 Old 06-11-2013, 02:43 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
You need a new fan clutch or solder and shrink wrap each connection that broke.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 6 Old 06-11-2013, 03:29 PM Thread Starter
Well crap. Thank you for the help brother, I appreciate it.
Jafruech is offline
post #6 of 6 Old 06-11-2013, 03:33 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
No problem.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
