New Injectors and Turbo no power under 2k - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-07-2013, 10:37 AM Thread Starter
Thenutisout's Avatar
I just installed all new injectors stock and a new stock turbo because I was having power issues under 2,000 RPM's. If I stomp the peddle from a dead stop it is a dog. After the new parts no real difference. Any ideas?
This is a 2003 Excursion 6.0 with 250,000 miles.
Thanks for anyone's help in advance.
2003 Excursion 6.0L 4x4 Eddie Bauer 247,000 miles
EGR Delete, MBRP 4". Everything else stock at the moment.
Thenutisout is offline
post #2 of 3 Old 06-07-2013, 01:00 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 554 Post(s)
Garage
EBP sensor clean?? Pull it out and clean tube as well, it's on the driver side valve cover height and a stainless steel tube that goes into exhaust manifold.
FICM voltages should be 48 volts at all speeds and temps.
Fuel pressure should be 60 psi and as low as 50 at wot.
Is it producing boost ?
ICP values ??
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 3 Old 06-08-2013, 03:09 AM Thread Starter
I'm gonna clean the ebp sensor today and check the fuel pressure also.
