EBP sensor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-07-2013, 06:08 AM Thread Starter
EBP sensor
My 07 threw a code for the EBP out of range type code on the way down to the family vacation campground. I got another sensor that I'm planning to replace today at the site. Here's the sensor reading at key on, engine off. Thoughts? I thought the value would match the psi of the manifold. Thanks in advance for any input!
hallfleming is offline
post #2 of 6 Old 06-07-2013, 08:18 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
KOEO test should show the EBP_A pid within 1.5 psi of the BARO and MAP pid's.
I would replace the sensor and clean the tube.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 6 Old 06-07-2013, 09:01 AM Thread Starter
Thanks for the reply! I disconnected the sensor and saw a reading of 140. It threw a code for the ebp being below range. When I plugged in the new sensor without installing, I saw the same value of 406. I guess Torque's Ford extended PID's aren't psi for that sensor?
post #4 of 6 Old 06-07-2013, 09:11 AM Thread Starter
Found the conversion for that PID in Torque. Torque Droid App to find EOT
post #5 of 6 Old 06-08-2013, 08:45 AM Thread Starter
New sensor installed. The pipe was nice and clean. I used the above PID values and now what I assume is psi. I thought it was supposed to shown close to manifold pressure at koeo but it's not. I do see that while driving it's within 1 or so values of the "boost pressure" gauge in Torque. Does that sounds correct?
post #6 of 6 Old 06-15-2013, 08:15 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
In a perfect world EBP/turbo boost would be 1/1. 2/1 is a good running combination thats not to hard on the engine for longevity.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
