04 6.0 long crankovers before firing up - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-06-2013, 06:31 PM Thread Starter
craigspeer2001's Avatar
I am having issue with long spins of starter before truck starts after it gets to running it runsfine plenty of power andcranks everytime wants its warm. I thought my fuel fiters were dirty so ichanged them and the oil it was time anyway so thats out the way. I had it scanned and glow plugs and injectors and all passed no codes what else can i look for. I noticed if you cycle th key four times it fires right up.
craigspeer2001 is offline
post #2 of 9 Old 06-06-2013, 06:38 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
How long are you cycling the key ? till glow light goes out?
I would look at the ficm voltages.
Fuel pressure.
ICP values.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 9 Old 06-07-2013, 06:51 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Genuine Ford Fuel filter or aftermarket?
AshevilleEngine.com is offline
post #4 of 9 Old 06-07-2013, 11:41 AM Thread Starter
cycling switch
I am trying to crank it as soon as light goes out.
post #5 of 9 Old 06-07-2013, 11:42 AM Thread Starter
Internatinal fuelfilters
post #6 of 9 Old 06-10-2013, 07:13 PM
Tow Dog's Avatar
I just got my motor back in my 2005 350 and hooked up and I'm having the same problem. I just did a refresh at 103,000
Main bearings
ARPs and stock head gaskets
2 reman heads
Fuel filters
Glow plugs/Harnesses
Rebuilt FICM from mastertech Ron
Performance machine coolant filter
EGR delete
Bed plate seals
Main seals
4" turbo back
I refilled the engine through the oil filter housing(15 qt) and it starts and runs and has oil pressure but nothing on the dipstick. Weird. Long crank then runs like a champ.
Tow Dog is offline
post #7 of 9 Old 06-13-2013, 06:19 AM
Quoted: 2 Post(s)
A lot of people have trouble when they are using an aftermarket fuel filter. I would think that an IH filter would be the same as Ford but who knows? Get a genuine Ford filter to see if it works before you worry about what else it could be.
post #8 of 9 Old 06-13-2013, 07:59 AM
Tow Dog's Avatar
Well, I changed my fuel filters and I think it fixed the problem. Also, I got 14.6 mpg towing yesterday!
Tow Dog is offline
post #9 of 9 Old 06-13-2013, 08:13 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
It could also be the wrong oil filter and or cap that leads to a long crank! Of course, you could have other issues that would require a monitor to see.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
