sputting/popping turbo smoke? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-06-2013, 02:01 PM Thread Starter
ok yesterday i took my car to work and today i decided to take my truck. well it only sat about a full day. usually i drive it everyday and on a cold start up it will have alittle smoke. well today when i tried starting it would not start crank only so i stop and tried again this time i kept on it for about 20 seconds and it finally fired up only with a **** load of smoke. so i leave and figured id get on it maybe clear it out. well i went wot and all i igot was this hesitation/sputtering/popping with no power.i looked in the mirror and then i saw a trail of white smoke. also the truck takes a country mile to get up and move when it does move. idkk what the problem could be. about 2 months ago i had 1,3,5,7,injectors replaced, new turbo, and the egr valve under warrenty i got the truck back and drove it for a week, and then did the egr delete with new oil cooler and everything else. the truck is not chipped. what could the problem be? any help would be appreciated
phillygp61 is offline
post #2 of 2 Old 06-07-2013, 06:45 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
If you are losing coolant, it could be a cracked head or head gasket leaking coolant into a cylinder
AshevilleEngine.com is offline
