Help with VGT isuue - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-06-2013, 01:05 PM Thread Starter
BB Wolf 63627's Avatar
Help with VGT isuue
VGT % stuck at 15%. I thought turbo was bad so I ordered a MTW stage 1 and installed it. Started truck and stuck on 85%. Talked to Adrian and he suggested it might be EBP clogged, IAT dirty, or MAP hose bad. I cleaned IAT which was dirty, checked MAP hose for leaks(none) and removed EBP tube and cleaned which was clean. Also made sure EBP fitting was not restricted. I purchased a new EBP sensor and it will run at 85% and old EBP sensor will run at 15%. Any other suggestions.
Weather I am 12 or 64 gonna live my life like there aint gonna be no more.
2005 F-250 HD edition
Linex Bed
Access Lorado cover
Edge Insight CS with EGT probe
Dieselsite coolant filter
Cat ELC
Kitty Delete pipe
K&N CAI with S&B filter
6.4 Banjo bolts
Upgraded Blue FPR spring
Rotella T-6 & Rev-X
Muff delete pipe
Glowshift Fuel pressure guage
SCT X3
IPR Gen II EGR Delete
IPR STC fitting
ARP Studs
Black Diamond Titanium Gaskets
Dummy Plugs & Stand Pipes
MTW Stage 1
BB Wolf 63627 is offline
post #2 of 2 Old 06-07-2013, 05:40 AM Thread Starter
Found problem I have 2 bad EBP sensors
Linex Bed
Access Lorado cover
Cat ELC
Kitty Delete pipe
6.4 Banjo bolts
Rotella T-6 & Rev-X
Muff delete pipe
SCT X3
IPR STC fitting
ARP Studs
MTW Stage 1
