Oil temp / cooler decisions... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-05-2013, 11:25 PM Thread Starter
I purchased a 180kmi 6.0 F250 (EGR deleted) a few months ago. I almost immediately discovered it needed an oil cooler replacement. Less than 1Kmi after replacement I started seeing progressively increasing 15deg EOT/ECT deltas (not towing). When I took it back to the shop they said the delta didn't matter and the temps were acceptable.
I'm seeing 215/195 on Hot days now (again not towing) and have a 9hour drive towing a toy hauler coming up. Little concerned temps will get worse when towing another 8klbs a long way from home.
What would you do?
mvastine is offline
post #2 of 3 Old 06-05-2013, 11:30 PM
turbotibbo's Avatar
if it was me , i would watch my oil temp close while towing . since the egr is deleted its not as bad so to speak . so mabey plan for an oil cooler in the future and watch temps .
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 3 Old 06-06-2013, 01:02 AM
JustinOOO9's Avatar
Quoted: 471 Post(s)
Garage
195 ect and 215eot? if thats temp driving on normal wihot load you need a oil cooler. make sure you flush your coolant system real good with vc-9 and distilled water good before you install a new oil cooler.
do not flush truck with new oil cooler it could possibly clog it. always always always flush before you install a new oil cooler.
1. drain coolant.
2. add 2 qrts of vc-9 and fill with regular garden hose water. drive it around no more then 3 hrs "warning on back of vc-9 bottles-
3. drain vc-9/ garden hose water.
4. fill with only distilled water drive it around for while.
5. drain
6. fill with distilled water and drive it around for a day or two
7. drain
8. replace oil cooler and use a cat/elc5 rated coolant I got it at napa for like 13$ a gallon.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
