Miss #8 contribution code - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-05-2013, 11:04 AM Thread Starter
Njstroker91's Avatar
Well lets start from the beginning I have had a contribution code in my truck for a while but recently it has begun to miss at initial startup and just missing the low end power. I have not dug in yet cause I wanna get some other options before I go throwing parts at it. First thing first the truck has become more smokey and takes a while for the charger to light off correctly. Once the charger lights it hits full boost at 28-30lbs it just doesn't pull as hard as it use to. My ficm volts are kinda questionable sometimes dipping down to 46.5 but always returning to 48.0-48.5. Ipr and calculated pressure all seem good maxing out around 3000 psi so I don't think it's a hpo leak. What I have found is as I hit the skinny pedal my fuel pressure will almost always spike the 100psi gauge doesn't seem to affect performance but doesn't seem right at all. The gauge has a brand new sending unit and is tapped right into the test port. Truck has 120000 and all mods are in sig. Anyone got anything I can check or have had similar problems that could lend some advice thanks ahead of time.
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #2 of 19 Old 06-05-2013, 02:23 PM Thread Starter
Well went out and did a few more tests cranking my ficm drops way down to 35 volts my voltage hovers around 11.5 then jumps up to 13.2. Still got the #8 contribution code after clearing but it sounds like I'm in need of a ficm.
post #3 of 19 Old 06-05-2013, 03:18 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I see hpop pressure as high as 3900 when I am in it hard ?? The smoke is most likely from lazy spool valves if the ficm voltage is low.
What do you mean by : the charger ??
Get the ficm fixed then see how it behaves IMO
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 19 Old 06-05-2013, 03:44 PM Thread Starter
The turbo is the charger lol but that 3000 psi isn't really wide open I don't really ever open her all the way up. But I'm definitely gonna order a bpd ficm and see how it acts then.
post #5 of 19 Old 06-06-2013, 08:20 AM Thread Starter
Ordered the bpd ficm 4phase should be here by Tuesday next week wasn't gonna pay the high shipping cost to overnight it.
post #6 of 19 Old 06-06-2013, 11:51 AM Thread Starter
No one has any ideas on the fuel pressure spiking only thing I'm leaning towards is a bad seal on the injector or my regulator hanging up and causing pressure to spike high.
post #7 of 19 Old 06-06-2013, 12:59 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I would lean towards the regulator hanging up on the return line. I would also take a look at the icp and ipr values at: idle/1500/2500 all at operating temp @195 degrees. The second generation hpop runs just over 4100 psi forget exact top pressure. Your miss may very well go away with a healthy ficm.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #8 of 19 Old 06-06-2013, 03:42 PM Thread Starter
Yeah that's what I'm hoping for a healthy ficm. My ipr and icp doesn't seem like its acting up. I know at idle the calculated pressure is only 450-500 @190 operating temp sounds about normal. Never really had a problem with rough starts unless it was winter time. It would buck and carry on but that sounds like the ficm starting to fail. Guess I gotta wait till Tuesday when it comes and see how it affects it.
post #9 of 19 Old 06-06-2013, 04:19 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I am surprised it runs at those pressures. The PCM turns on the ficm at 500 psi and normal ICP pressure at idle is 580 and 21% IPR. I lost all my figures through the different rpm's but can look them back up.
I know that the ICP pressures at upper rpm's under a load are around 3900 psi. This pressure is what puts the fuel in at the injectors. You may have a ICP that's off a bit but maybe not. I would take a close look at it and the pigtail and check for any oil coming out of it. I will look up the ICP values at the different rpm's and you can compare it to your truck.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #10 of 19 Old 06-06-2013, 04:33 PM Thread Starter
Alright great thanks maybe this is a little further of an issue then I thought I know the ipr is at 21% at idle with the reading fluxuating anywhere from mid 400 to mid 500 I should try disconnecting the sensor and see if it the idle smooths out a bit. I wish I could go get some more reading but I'm on nights tonight so won't be able to till the morning
