Oil Leak Around Turbo.. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-03-2013, 07:34 PM Thread Starter
I'm leaking oil around/on/under the turbo. It runs down the passenger side of the block with a lot on the starter. I'm leaning towards a seal on the turbo oil feed/drain lines which I've ordered, is there anything else it could be? This happened after an oil cooler/egr delete job by the way..
2006 F250 ECSB 4x4 Lariat
168k Miles|FICM by Ed w/ Atlas 40|SCT X4 with Tunes by Vivian|MBRP 4" TBE|Zerex ELC|EGR Delete and Coolant Filter by Custom Diesel|ARP Studs|OEM Gaskets
2008 F450 CCLB 4x4 XLT
141K Miles|Bone Stock for Now...
jtheado is offline
post #2 of 9 Old 06-03-2013, 10:46 PM
HarvestingInternationally's Avatar
Did u seat the drain pipe correctly to the hpop...new o rings? Did u grease the o rings? Did it seat correctly on the turbo ?
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 9 Old 06-03-2013, 11:20 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Besides the turbo, it is quite possible you may have a leak from the oil cooler housing.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 9 Old 06-04-2013, 02:43 AM Thread Starter
I used new orings and grease the fittings but I'm thinking i might have not got the drain pipe in all the way..how much should the pipe move when it's in there?
And i don't think it's the oil cooler cover because there is really no oil coming from around that area, it's mostly around the pedestal.
Sent from AutoGuide.com App
jtheado is offline
post #5 of 9 Old 06-04-2013, 02:50 AM
pjsf250's Avatar
did you check the seal on the turbo oil feed line on top
when i did mine i did not have that tight and oil was dripping down on pedestal
like yours
pjsf250 is offline
post #6 of 9 Old 06-04-2013, 03:08 AM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
The turbo drain should pop in easily with grease and fully seat, it moves abound a bit for turbo alignment.possible you damaged the top oring when reinstalling the turbo.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #7 of 9 Old 06-04-2013, 08:08 AM
Quoted: 46 Post(s)
You have an 06, so you have the new style drain pipe. The key is to install the pipe in the HPOP cover and have it sit in the correct spot on the pedestal. If you don't hit it out of position when installing the turbo, it usually seats quite easily. The o-rings are fairly robust, but sometimes if you drag enough dirt into the seal mating surface it can leak. I guess you will be going back to re-seat the turbo.
Frank
Working for Toys
post #8 of 9 Old 06-13-2013, 06:05 PM Thread Starter
like yours
You were correct sir! I only got a quarter turn out of it with a stubby wrench but it solved the problem.
jtheado is offline
post #9 of 9 Old 06-13-2013, 06:40 PM
^ glad to hear
2006
, Fuel Pressure)
Eric
