FICM? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-03-2013, 04:19 PM Thread Starter
KOOOPSD's Avatar
Send a message via AIM to KOOOPSD
FICM?
FICM is corrently in route to FICMrepair.com due to low voltage, could that be the reason my truck had a slight miss at idle and noticable miss when into the go pedal?? I have no white smoke at idle or accelerating and the truck starts warm or cold just fine, No check engine lights either, Injectors only have 7000 miles on them, could i have a bad injector aswell???
2006 F250 Lariat
-SCT w/ Innovative Diesel Tunes
-ARP Studs and EGR Delete
-Airaid Intake
-4" Downpipe into a 7" tip
-37/13.50/20 Toyo Open Country Mt's
-4.5" suspension lift
Used to have a 99.5 7.3 Stroke
KOOOPSD is offline
post #2 of 11 Old 06-03-2013, 04:32 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
The best person to talk to about the ficm is Ed himself at FICMREPAIR. A wealth of ficm knowledge!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 11 Old 06-03-2013, 04:35 PM Thread Starter
KOOOPSD's Avatar
Ok, i was just curious, i guess ill know in a couple days anyways when he returns it if its still missing at all!
Sent from AutoGuide.com App
2006 F250 Lariat
-Airaid Intake
KOOOPSD is offline
post #4 of 11 Old 06-03-2013, 04:38 PM
Marine Raiders>Seals
najaf4life's Avatar
So you sent off your FICM without knowing if it was low on voltage or not?
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #5 of 11 Old 06-03-2013, 04:41 PM Thread Starter
KOOOPSD's Avatar
If u read my post it says it is in route due to low voltage
2006 F250 Lariat
-Airaid Intake
KOOOPSD is offline
post #6 of 11 Old 06-03-2013, 04:45 PM
najaf4life's Avatar
Sorry missed that some how. How low was your voltage?
RYAN
03 Excursion 6.0L
post #7 of 11 Old 06-03-2013, 04:46 PM Thread Starter
KOOOPSD's Avatar
Anywhere from 35-42v at start up... With it running high idle for 2 mins or so it was 46-48v
2006 F250 Lariat
-Airaid Intake
KOOOPSD is offline
post #8 of 11 Old 06-03-2013, 04:48 PM Thread Starter
KOOOPSD's Avatar
That was off my scan gauge.... That being said, it was telling me my trucks voltage was only 10 volts after sitting for a week so i pulled the batteries when i pulled the FICM and with a meter my batteries are both reading 12v each. So i dont think the scan gauge is too accurate
2006 F250 Lariat
-Airaid Intake
KOOOPSD is offline
post #9 of 11 Old 06-03-2013, 04:49 PM
najaf4life's Avatar
I'd say most likely it's just your FICM. If it was a injector you would have a CEL and it wouldn't idle or drive correctly.
RYAN
03 Excursion 6.0L
post #10 of 11 Old 06-03-2013, 10:24 PM
Badger76's Avatar
Quoted: 2 Post(s)
I know ED called me when it was fixed and what they did to it. If your curious wait till you think its there and give him a call he should be able to help hes really upfront with you. I just got mine back from there and trucks runs awesome.
2005 F-250 XLT ECSB 6.0 ZF6, Atlas 40, ARPs, Blue Spring, IPR Coolant Filter, Delete, QT Tunes, Rotella ELC, Cutting Edge Up-Pipes
Badger76 is offline
