Custom tune = coolant puke, stock tune = no puke - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-03-2013, 02:39 PM Thread Starter
Ok guys, here's a good riddle for ya.
Back in November of last year I did the big upgrade on my Powerstroke. Did everything short of new head studs: SCT tuner and loaded the custom tunes from Innovative, EGR delete, oil cooler replace, new radiator cap, and 4" exhaust, etc. Results were great. However, now we are having issues with our coolant puking out of the degas tank. I know, you jump to the conclusion that its our head gaskets, but bare with me for a second. I performed this simple test:
- Installed coolant pressure gauge
- Truck is F-350, crew cab, dually, towing 26' enclosed trailer roughly empty
- Identified good stretch of road with slight hills, able to get up to ~70mph, ran it as hard as I could
- With tow tune in truck -> coolant pressure got up to ~17psi, boost maxed out ~27psi, coolant puked
- Refilled coolant and returned tune to stock -> coolant pressure only gets up to ~5psi, boost easily pegs 30psi, no coolant puke
- ECT and EOT delta never got above 12F
From this data, to me, it doesn't appear to be a head gasket at all, however, I have no clue what it could be. One other observation is that until now, it has been cooler temperatures, but now we are getting into the summer months (we are in Auburn, Al). If you have other tests we could run or anything at all that might help, it would be greatly appreciated. Anyone ever seen anything like this?
Thanks!
griffgj is offline
post #2 of 19 Old 06-03-2013, 03:05 PM
SoCal60 is offline
post #3 of 19 Old 06-03-2013, 03:30 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Yea that is pretty common to head gasket failure. With a tune there is more cylinder pressure to push it's way out and into the cooling system.
You do know that the boost is manipulated so the pcm sees lower boost pressures when in reality the pressure is higher than what you are seeing on the gauge.
Hate to say it but you have head gasket failure. The cooling system should operate in the 8-10 psi range if you see more than 14 lbs. you have a problem. If you put a solid cap on the coolant tank it would climb till the hoses split.
If you watch the pressure gauge and stand on the throttle you will see a pressure spike within a few seconds when there is head gasket failure. Sorry for the bad news.
Like the Anti Nausea comment SoCal, malox may be needed too. lol
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #4 of 19 Old 06-03-2013, 04:01 PM Thread Starter
That's what I was thinking.
I was reading my aftermarket gauge
I may be fighting tooth and nail on this one, but when it's cold, I'll punch it, on either tune, and see no spike in pressure. This is one of the tests that's keeping me hopeful...
griffgj is offline
post #5 of 19 Old 06-03-2013, 05:00 PM
Snake's Avatar
Quoted: 46 Post(s)
Your head gaskets are blown.
Put the truck back to stock and get it up to temp. Once there, relieve any pressure in the degas bottle (take the cap off).
Do some WOT runs from 0-speed limit (or maybe a little over). Add in some acceleration when you drop the truck out of OD and hammer it.
I'll just about guarantee you'll have excessive pressure in the degas bottle. I had similar symptoms and elected to tear things apart again. Confirmed my head gaskets were blown once the heads were pulled.
It's ok though. The first step to recovery is admitting you have a problem. You're still in Stage 1: Denial.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 19 Old 06-03-2013, 07:45 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Yea it's all fun and games until what can happen happens.
My truck is stock for that very reason. I do have the Atlas40 ficm tune and 4" straight exhaust but there is no change in cylinder pressure from these mods.
Head studs will take care of the problem.
Atlas40
BPD Waterpump
Fabtech Radius Arms
post #7 of 19 Old 11-10-2013, 12:02 PM
Resurrecting this thread from the dead.
I got the same thing going on, If i run vivians looney tune it pukes (well it did once anyways and that was enough for me) but then on the stock tune I ran it hard and it doesnt puke.
My Deltas are ok like 6 degrees so it would seem to be a head gasket issue (although I do still have the EGR cooler fully intact). Is is it def a head gasket issue or do I really just need to get the EGR cooler outta there asap?
AND mhatlen, Hopefully youre still around? Im curious how the truck runs with just the FICM tune and no Tuner. Most I come across have stacked tunes. What kind of improvements did you see, and did it affect MPGs?
Stlavsa is offline
post #8 of 19 Old 11-10-2013, 01:53 PM
Quoted: 57 Post(s)
Most likely it's blown head gaskets. Need to put a pressure gauge on the cooling system and this will help confirm. Are you studded?
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #9 of 19 Old 11-10-2013, 02:16 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
The egr cooler would leak with or without a tuner. If you egr cooler was plugged you would not have 6* delta temps so those are both in good shape.
You could very well go for years and be problem free as long as you keep the tuner out of it.
I have a buddy with a 03 that was tuned and turning 12.82 in the 1/4 mile that was doing the same thing. With tuner it was blowing out coolant no tuner no problem.
He has been driving it now for over 2 years without any issues.
It depends on how far it goes for leaking, the heads can lift just enough for coolant in the water jacket to get by with the additional pressure. No more tuner no more problems, gaskets have not been gouged from gases or coolant leaking by for a extended period.
As far as the FICM tune goes: I have 4" straight piped exhaust along with the Atlas 40 tune only. I have no idea what truck would do in the 1/4 mile, but considering I have 38" tires it wouldn't be too impressive. What I can say is there is pretty good improvement in power especially at 55mph up. Highway passing power is much better as well as off the line.
It will blow black smoke when floored and it didn't do that before, so there is much more fuel delivery with it.
Funny thing is my mileage went up 2+mpg on the highway. I was getting 13-14mpg and now I can get high 16-17 now at 70mph.
People do stack the FICM tune on top of a tuner but there is not as much improvement being tuners usually address the FICM so fuel strategy is already increased.
I myself like the FICM tune and it does not increase cylinder pressures like tuners will through timing and increased boost or increased hpo pressures.
Atlas40
BPD Waterpump
Fabtech Radius Arms
post #10 of 19 Old 11-11-2013, 05:45 AM
mhatlen:
Thanks for the reply, everything you said is kinda what I'm under the impression is going on right now.
My ECT temps are 187-190 and my OCT temps are 188-193, with or without a tune. I was kinda thinking that my EGR Cooler and Oil cooler are still OK, and that if the EGR cooler ruptured that I would have problems with coolant temp?
I've only had the looney tune on for less than 50 miles, and only 3-4 full throttle runs, so MAYBE the damage is limited?!
When I bought the truck a month ago, i did it fully planning on doing studs and a delete (just havent done it yet.) And since I spent a bunch of cash just buying the truck I was planning on saving a lil $ up before dropping $3500 on studs n delete.
I'm glad to hear that youre buddy was able to run his truck like that, I am trying to decide what to do. I have the $ to bulletproof it right now, but seeing that the holidays are upon us, etc. IT would be nice to just get the truck through winter and address the problems in the spring time.
I am kinda hoping that it wont be a problem driving it like this if the i just run the stock tune, and it doesnt puke. My concern was that if the EGR cooler is ruptured, that I will end up doing big time damage before i can get it all addressed. Since the ECT is OK is it safe to assume the EGR cooler is?
Stlavsa is offline
