Power Loss/Oil Leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-03-2013, 01:38 PM Thread Starter
Question Power Loss/Oil Leak
Hey guys, newbie here, hoping to get some direction/advice. My truck is a 2003 6.0 F-350, bought two years ago now with 102,000. For several months I've been getting an on/off whiff of coolant. Took it to Ford for pressure testing three months ago and they said it checked out, no leaks.
Saturday I was hauling my race car back from Thompson, OH. The antifreeze smell became consistent, turning to an even uglier smell and a serious loss of power. Boost guage was cycling back and forth and sounded like the turbo was hitting an air release valve (waste gate?). Black smoke puffing on acceleration. Limped it home and discovered oil leaking on the tranny housing and driveshaft near the coupler.
The coolant appears a bit dark (not sure of original color), but not overly oily. From what I can tell off that dinky dipstick tip there doesn't seem to be coolant in the oil, not milky looking.
No overheating, but coolant level was slightly below MIN and hadn't checked it since Ford looked at it.
Anyone have any ideas? Help! I wrench on gas, but lost on these smokers. EGR valve/sensor maybe?
DH9185 is offline
post #2 of 4 Old 06-03-2013, 06:51 PM
06Lariat_'s Avatar
If coolant is black you could have a ruptured oil cooler.
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #3 of 4 Old 06-03-2013, 07:09 PM Thread Starter
Thanks Lariat. I'd describe the coolant color as a light gray, so you may have it right. Seems it's necessary to pull the manifold to fix this, ugh. Do you think this would cause the power loss and bad smell? Dave
DH9185 is offline
post #4 of 4 Old 06-03-2013, 08:30 PM
06Lariat_'s Avatar
Well I'm sure if it puking or actually leaking from the cooler it would smell. Lack of power idk maybey there's a hpop leak as well.
Leveling kit
Smoked cab lights
Blue spring upgrade
Riff raff boots
