P0671-P0678 all glow plug code - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-03-2013, 08:58 AM Thread Starter
dcbutcher's Avatar
So I've posted this separately just to see if I can get more info. Third start of the day yesterday all codes flipped and continue to flip everytime I start it. I've read about testing the module but not great with electronics. Any ideas on next step or should I attempt it? Also I've read there is no fuse for the glow plugs is that correct?
2005 F350 6.0
Sent from AutoGuide.com App
2005 F350 6.0 King Ranch
SCT SF3 w/ Looney Wild Tune
Air Dog 2
XDP Fuel Sump
EGR Delete
Head Studs
4" Turbo Back
Edge Insight
Cat ELC coolant
Garret Powermax GT3788va
dcbutcher is offline
post #2 of 6 Old 01-28-2014, 08:23 PM
JonnyP's Avatar
Did you ever figure out what was wrong? I just had the dealership replace my EGR cooler, oil cooler and had the turbo cleaned. Now I get codes for all of my glow plugs and even some for my EGR valve (P0403,P0405).
2003 F350 stock 6.0L
Banks Monster muffler
5" lift
295x60x20
JonnyP is offline
post #3 of 6 Old 01-28-2014, 08:33 PM Thread Starter
dcbutcher's Avatar
Jonny, I can't be certain what the issue was. I replaced all the fuseable links that run to the passenger side battery and it resolved the problem. Wish I had more info to help ya. Good luck!
Air Dog 2
XDP Fuel Sump
EGR Delete
Head Studs
4" Turbo Back
Edge Insight
Cat ELC coolant
post #4 of 6 Old 01-28-2014, 10:04 PM
I would suspect a controller or wireing issue more than all eight glow plugs or even a majority going out all at once.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 6 Old 03-24-2014, 04:30 PM
x96535's Avatar
Would you mind elaborating? I'm terrible with electronics as well. Just replaced my GPCM and still getting the same P0671-P0678 codes. Where are the fuses that you replaced exactly?
2005 F-250 CCSB 6.0L: SCT X3, IDP Tunes, CTS Insight, 2.5" Leveling Kit, 35" Toyo's, 20" KMC Wheels, Rancho 7000's, EGR Delete, ARP Studs, Updated FICM, Built Tranny, '03 Turbo, 3" Downpipe, 4" MBRP Exhaust, Blue Spring Mod, 20" Lightbar, Door Seal Mod, BedRug, UnderCover Flex Cover, Badges Shaved, Painted Grille, Handles, & Mirrors, HD Headlights, Tinted Tails, 5% Tint
x96535 is offline
post #6 of 6 Old 03-24-2014, 04:32 PM Thread Starter
dcbutcher's Avatar
On the passenger side battery there are stock wires that I believe run from the alternator, one large gauge wire is split into 3 or maybe 4 smaller wires. Inside these wires are fuseable links. This is just my understanding but I, like yourself, am terrible when it comes to electrical issues
Air Dog 2
XDP Fuel Sump
EGR Delete
Head Studs
4" Turbo Back
Edge Insight
Cat ELC coolant
