turbo making loud high pitched sound - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-02-2013, 06:54 AM Thread Starter
superBADduty's Avatar
Quoted: 17 Post(s)
Garage
I did a search and found that many people say too look at the up pipes, bellows, and v clamps. I dont see any soot on the back wall. It sounds like a screach, only at idle or just off idle. When i give it more throttle it goes away but when i slow down to come to a stop it starts again.
I unplugged the vgt (in park) and the sound goes away. I plug it back in and it starts making the sound again right away.
Any thought?
2007 F250 KR CCSB 4x4 ARP's, PMM's EGR delete, PMM's coolant filter, SCT Sf3, GearHead's SRL & SRLXX, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel 2, No Limit Fab. CAI., 2008 rear differential cover.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
2008 F250 KR CCSB 4x4 quad buckets minimax "SOLD"
superBADduty is offline
post #2 of 2 Old 06-02-2013, 09:36 AM
PlatinumDiesel's Avatar
Vgt solenoid is bad. Pull the turbo and I believe it's one bolt holding it in. Simple to replace. I take wd-40 and spray it in the oil inlet and hit the compressor wheel with compressed air to free it up from any coked oil that may have baked. Remove the turbine housing on the turbo and clean up any **** on the unison ring. Use anti seize and coat everything lightly.
Sent from AutoGuide.com App
PlatinumDiesel is offline
