ECT and EOT temps. Caught in time? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-02-2013, 03:57 AM Thread Starter
KCCO
KMC_A55's Avatar
Well, I do not need help with this issue as I already know what it is and tomorrow I will be taking it in to the dealership to get it fixed under warranty, however, I thought I would share my ECT/EOT numbers with everybody.
I just bought this truck a couple weeks ago from a reputable dealership around here and the truck only has 78K miles on it. I found a super sweet deal on an older edge platinum juice with attitude, and while I did not do any tunes, I just wanted it to monitor my levels and such.
So I get home and plug it in and drive it to work the next day. I set the cruise to about 65 MPH so I can get a good baseline on my cooling system numbers and what not.
Well here's the fun part, my ECT stayed right around 190 (186-190) but my EOT? My EOT stayed at about 242 after about 15 minutes of driving it!
I think there might be a problem there. haha. No coolant lose, and no coolant spitting out of the degas bottle though so I think I caught it in time before any major damage was done. Needless to say, I parked the truck until I can take it to a reputable ford dealership to get it fixed under warranty.
2003 F-350 6.0L. CCLB, 6" lift on 35's, 110k miles: Sinister coolant Filter, Sinister EGR delete, Sinister boots, ARP studs, Powermax Turbo, Diamond Eye 4" turboback exhaust, cat-elc, blue spring update, 6.4 banjo bolts, Edge CTS w/ EGT, SCT w/ Gearhead SRL+ tunes, S&B air intake, Atlas 80 FICM tune, water/meth injection, high idle switch, fog light mod, zoodad mod, 07 front end, 07 dash, 08 taillights, 08 mirrors, 14 tailgate,
upfitters, Lock-Right Locker
KMC_A55 is offline
post #2 of 13 Old 06-02-2013, 04:10 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Wow that's a crazy bad eot
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 13 Old 06-02-2013, 02:34 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
Are the ECT and EOT temps the same after sitting overnight before you start the truck ?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 13 Old 06-02-2013, 02:42 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
A couple of more degrees and she should have went into limp mode. Nice catch.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #5 of 13 Old 06-02-2013, 03:09 PM Thread Starter
KCCO
KMC_A55's Avatar
After sitting overnight, yes, the temps equal out(well actually when first started the ECT is warmer than the EOT and then the EOT slowly catches and then keeps going up). Then after about 15 mins of driving whether highway or in town, the ECT smooths out about 190 and EOT slowly keeps climbing to 242. My thought is plugger oil cooler. Are you think maybe something else?
KMC_A55 is offline
post #6 of 13 Old 06-02-2013, 03:19 PM
T diesel's Avatar
Quoted: 21 Post(s)
Good catch!
I'd have the blue spring upgrade done while it's there.
2013 F-250 lariat scsb FX4.
6.2. 3.73 lockers. Rear wheel liners.
Camper package. Pullrite 18K lb Superslide, Line X sprayed bed.
Krown rust protected.
"That which can be asserted without evidence, can be dismissed without evidence"
- Christopher Hitchens
T diesel is offline
post #7 of 13 Old 06-02-2013, 03:26 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 126 Post(s)
Feedback Score: 7 reviews
holy cow that is high EOT!
powerstrokeshellback is offline
post #8 of 13 Old 06-02-2013, 04:28 PM
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
A coolant filter is the biggie here,the cooling system is what's killing the oil cooler.
On my truck I drained all the Ford Gold out pulled the thermostat and flushed out with water. Filled up cooling system with water and put in 2/3 cup of Cascade liquid dishwasher soap. I took truck for a 30 mile drive and drained out cooling system. Pulled all the hoses off of coolant recovery tank as well as the bypass and upper and lower hoses so I could run hose through everything. Refilled and flushed three time using only distilled water draining everything after short drives including the block drain plug on drivers side.
It cleaned my cooling system well the thing that I noticed right away was that my heater worked much better, was much hotter out of vents. I have since put in Cat EC1 coolant and it's been around 1-1/2 years and my delta temps today are still in the 4-5 degree range. I change coolant filter every 6 months or so and the filter barely catches anything these days. There are some high quality filters out there like IPR full flow model, I have the blue one forget who makes it. lol but it's a must have item for the 6.0 and so is the blue spring for the fuel pressure regulator.
7" Icon/Carli Lift
Atlas40
4" SS exhaust
58K Miles on it
mhatlen is offline
post #9 of 13 Old 06-07-2013, 06:43 PM Thread Starter
KCCO
KMC_A55's Avatar
Yeah mhatlen, I just ordered my coolant filter. I will be sure to drain and flush the cooling system and then refill with the Cat EC1 coolant. Where does a person buy that stuff? And I have just recently been looking into the blue spring mod, I will probably do that as well when I change the oil cooler.
Normally I do all my work myself, because I have always bought older vehicles with no warranty. Since this one has a warranty I did some searching around and found an awesome guy out here who is very very friendly to mods to the 6.0 while still doing whatever he can to keep it under warranty. He said he will take care of me and so far has been nothing but helpful with me!
KMC_A55 is offline
post #10 of 13 Old 06-08-2013, 02:41 AM
T diesel's Avatar
Quoted: 21 Post(s)
Watch these videos on flushing.
If you google international dealer and find one. call and ask for fleetrite elc CONCENTRATE red cap vs. black cap. Get four gallons.
T diesel is offline
