Another High Pressure Oil Issue - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-01-2013, 12:19 PM Thread Starter
DBM
Well, a week after installing a BPD oil cooler and an MTW stage 1 turbo, (both of which I am really happy with thus far), I came out to go to work and get a crank no-start. I did see ~350 PSI icp pressure on my CTS, I was in a hurry to get to work and didn't look very hard. I'm thinking IPR issue, I need to go home tonight and hook up AE.
"have not shot the gun yet but will next week when we see the mother in law." Quoted from a gun forum!
2004 CC 6.0 4x4 lariat
MODS: BPD Remote Oil Cooler, MTW Stage 1, GoGo Diesel Direct Drive Soleniod, Swamps 58v FICM, ARP's, Sinister EGR Delete, SCT XCAL3 w/DJ's Looney, Dfuser coolant filter, 4" straight pipe, Ranch Hand, Tuff-Country Level Kit, Isspro Boost/Trans Temp/Fuel Pressure/Pyro gauges, Edge Insight CTS...
DBM is offline
post #2 of 20 Old 06-01-2013, 12:24 PM Thread Starter
DBM
Update... I went out and hooked up my AE and cranked on the truck to record some data, and just as I was letting off of the key, the RPM started to climb. It was 10 or 12 seconds, so I tried to crank it again and it started after about 10 more seconds. So I took it for a drive and stood on it and got 4000 PSI ICP. So now I am thinking I need to pull the IPR and check the screen, I feel like it had trash in it holding it open. does this sound reasonable?
DBM is offline
post #3 of 20 Old 06-01-2013, 12:42 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
It sounds more like a HPO leak to me.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 20 Old 06-01-2013, 08:28 PM Thread Starter
DBM
More info, decided to take the truck to find a fitting to test the hop system, and it is starting in less than 2 seconds of crank time hot and cold and acting like nothing ever happened...
DBM is offline
post #5 of 20 Old 06-10-2013, 05:41 PM Thread Starter
DBM
Well that lasted about 3 days, on the forth day no start again, now ICP reads about 250 psi. I ordered an IPR socket, an adapter to do the air test and an IPR pigtail, well the socket came in so I pulled the ipr, and it doesn't have a screen on it. could it still be in the housing? how does it attach on the ipr valve? could I crank the truck and purge the ipr port with oil?
DBM is offline
post #6 of 20 Old 06-10-2013, 07:16 PM
the screen is stuck in the housing. Just use a pick to get it out.. Or do what I did and suck it out with a vacuum cleaner. No need to purge
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #7 of 20 Old 06-11-2013, 08:11 PM Thread Starter
DBM
Got my screen out today, thanks, 04cr450, about half of the lip is missing, the screen is concave shaped, it had a fair amount of grit on it, but no metal, and the screen is split as you can see.
DBM is offline
post #8 of 20 Old 06-11-2013, 08:16 PM Thread Starter
DBM
I also got my pigtail today and was testing the valve in hand and it clicks when voltage is first applied, but it needed about 5 seconds to open back up, is this normal operation? My guess is it opens a lot faster when exposed to hp oil.
DBM is offline
post #9 of 20 Old 06-12-2013, 05:54 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Based on your screen, you should just change out the IPR. You may be able to clean it, but you won't know the integrity of the regulator going forward. However, now that you have the socket, you could live in the fast lane as long as you have the new one ready to install. Of course, it ussually will break away from home, at night, when it is raining and you need to be somewhere!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is online now
post #10 of 20 Old 06-12-2013, 05:55 AM
dxusmc's Avatar
Ain't that the truth.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
