ICP high and Idle miss - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-01-2013, 07:10 AM Thread Starter
Hello all,
I have 2004 6.0 with 120k. regular oil changes. Newer design with ICP on valve cover. I have had a rough idle issue for over a year that gets better and worse for no appearent reason. I thought it was a surging issue as i start to let of brake at a stop light i found that its definatley a miss not a surge. The only things I have found to be off are high ICP. I am pushing 4.5-4.8v icp at half throttle through WOT all the time measured by Edge guage and it is this way when in stock or stage 2 mode. checked for loose grounds, pulled IPR no damage or flakes, truck always starts and even when having bad miss at idle once you touch the accel pedal truck runs great and cant feel any misses at all while driving or towing. RPM guage at idle doesnt move at all when missing. Truck has never died or not started quick. Miss is getting worse but even the shop has no clue. FICM has constant 48.5 or 49v. FICM connectors found to have broke clips holding them in so I zipped the on but problem is the same. What would cause high ICP always. Could faulty IPR cause rough running. ICP looks good no oil in plug.
Im just looking for any ideas since the shop has none. Anyone have something like this happen. I dont think its stiction as it happens mainly when warm.
zachyfarms is offline
post #2 of 3 Old 06-01-2013, 09:40 AM
PlatinumDiesel's Avatar
Bad icp sensor and pigtail or stiction. Buy the sensor, buy the pigtail and splice it in. When it's doing it, unplug the icp and watch what happens. Rev-x isn't the worst idea either. Help if it could be stiction. Doubt it. Still buy it tho
Sent from AutoGuide.com App
PlatinumDiesel is offline
post #3 of 3 Old 06-01-2013, 10:01 AM Thread Starter
yeah I have been running revx.. Unplugging the ICP doesnt change the miss at all.. I just read a couple things showing the EGR causing a similar miss like mine. Im going to clean it again and make sure o rings are good.
