2005 6.0 Hot start problem - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-01-2013, 06:19 AM Thread Starter
Cobiaman's Avatar
Ok guys I have 2005 Powerstroke with 120k. My mods include Volant air intake, EGR delete, Edge Platinum performance module and Magnaflow exhaust from Turbo back.
My issue started about month ago. When I cold start she starts well no problems. But once she runs and is hot takes a long time to crank Feels lilke gonna leave me stranded. All my routine maintainence is up to date. New filters and oil change. No DTC codes on my Edge module popping up! Have appt with local dealer. What I'm seeing posted is High pressure oil side! Dummy plugs, STC fitting,ICP issue? Any response would be appreciated. Just wanna have some facts before I go to the Ford dealer!
Thanks Powerstroke Family!
Cobiaman is offline
post #2 of 8 Old 06-01-2013, 07:14 AM
Yep to all of the above. I am currently dealing with this issue and found that my injector 0rings were bad. The dealer will probably do an air test. I stayed for mine. The oil "manifold" ( somebody smarter than I am correctly call it). Was also leaking around the nipples on it. This has been a hard, expensive month for me and the 6.0.
Suprob is offline
post #3 of 8 Old 06-01-2013, 06:32 PM
Louiediesel's Avatar
keep on eye on your batteries, I also been having same issues,replaced dummy plugs and stand pipes with the updated ones,couple of injectors,new Icp,and today 2 new batteries because one of them was weak and theses beasts demand alot of cranking amps to fired them up
Louiediesel is offline
post #4 of 8 Old 06-02-2013, 05:36 AM Thread Starter
Cobiaman's Avatar
Thanks for feedback
Cobiaman is offline
post #5 of 8 Old 06-05-2013, 03:57 AM Thread Starter
Cobiaman's Avatar
Hot start issue
Well the diagnosis is in Oil rail plugs and ICP fitting kit are leaking and need to be changed! Parts not that bad $300-400 but the labor is the big part of the price! At the local dealer I'm being quoted $2000. I know its a big job and I can't fix it but it stings when you get that price. I think they call for about 15hrs labor. Seems excessive but I'm not the expert. But I know the FORD Experts surf this site an their input is appreciated. Anyway she gonna get fixed!
Cobiaman is offline
post #6 of 8 Old 06-05-2013, 04:31 AM
The independant shop who did my heads studs (and dummy plugs/standpipes at the same time) charged my 20 or 25 hours labor for the whole deal.
15 hours seems quite a bit high for just the plugs. I don't know what is right, but I am thinking it should be closer to 3 hours.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #7 of 8 Old 06-06-2013, 07:37 PM
I would say give it a shot. I did mine a few months back and its ALOT easier than you think. Spent about 7 hrs each side and I took my time and cleaned everything really good. Only thing that isnt a "common" tool per se is cherry picker. Youll have to lift the pass. Side up with the picker about 2 in to remove the standpipe. You could use a floor jack and some wood im sure though. Other than that youll need a torque wrench that can do 60lbs I think, a 12mm hex bit or torx 60, and I believe a 10mm hex bit. Id the standpipe splits (one of mine did) youll have to remove the oil rail with a t30 and im not 100% but I think they are 12 lbs. I planned on using a 4 day to do this but I did it no problem in 2. The hours I put in include prep and cleanup and starting. I can look into it and tell you the exact specs if you need.
ajfrac is offline
post #8 of 8 Old 06-10-2013, 02:33 AM Thread Starter
Cobiaman's Avatar
Well got her back on Friday earlier that expected. The tech also found a heater hose that was about to start leaking so he changed it. He also showed me all the parts and the wear on them and explained everything in detail. I was really impressed! He changed the oil stand pipes, dummy pipes, STC fitting and heater hose. Cost me 2200.00 but I didn't realize how fast the truck could actually start. I satisfied with the work peformed and would definitly recommmend the diesel tech at local dealership to fellow Powerstrokers! Have a Great WEEK!
Cobiaman is offline
Tags
hot start problems
