High Egt's - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-01-2013, 06:37 AM Thread Starter
casper4203's Avatar
High Egt's
For a while I have been watching my Edge to see what is causing a problem I've been having.
When pulling heavy, I noticed sometimes my EGT's get up to the point of setting off my alarm setting of 1200*. I've been wondering why sometimes it's been fine and then shortly in the same few minutes, it spikes. It's when the TC is locked and at high cruising speeds with slight acceleration.
After watching closer, I see that when the turbo boost hangs around 10+ psi. all is good. When the EGT's go up the boost is under 10 psi..
So when I kick into it, it eventually gets back to its normal routine.
My first though is maybe a sticking or failing VGT solenoid.
Thanks any input.
"casper"
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #2 of 5 Old 06-01-2013, 12:37 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
1200ļ EGT's are not that hot and nothing to worry about for towing.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 5 Old 06-02-2013, 03:29 PM Thread Starter
casper4203's Avatar
Yeah I know what you're saying. But I can something going on.
When I'm on flat ground and accelerating slightly it goes back and forth between this situation I'm seeing.
I'm going to try pulling out the VGT solenoid to see if it looks ok. Do these get sooted up?
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #4 of 5 Old 06-02-2013, 05:52 PM
04cr450's Avatar
yes 1200 is fine, BUT its nothing to pull the turbo and clean it etc etc.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 5 Old 06-02-2013, 11:39 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
A leak before the turbo can give high exhaust temps.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
