foreign object in injector! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-31-2013, 10:22 AM Thread Starter
Quoted: 28 Post(s)
So after an injector replacement I took it apart to see what was wrong with it. and I am kinda stumped and scared... After taking off the electrical solenoids i tried to take out the oil "shuttle pin" and it was jammed. That makes sense for the injector not passing a buzz test. I just tapped it on my workbench upside down and out came this little piece of metal and the "pin" would move. Now I had a good fight removing this pin but it was scored pretty good in the valleys of the pin. Im gonna try to attach a picture of the Foreign Object next to a 10 mm socket. I hope anybody can tell me where this might have come from...
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #2 of 6 Old 05-31-2013, 03:05 PM
That looks like a piece of roller bearing from a lifter but I shure don't see how it got there. That had to travel a ways thru the system.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 05-31-2013, 04:51 PM Thread Starter
Quoted: 28 Post(s)
It kind of looks like a keyway or a part of the snap to connect fitting. I still am able to get and maintain 4.8 volts of icp voltage. I'm guessing my hpop is didn't push it through!
06 350 CCLB
Edge CTS
ARP's
Coolant filter
rentstdi is offline
post #4 of 6 Old 05-31-2013, 06:20 PM
HarvestingInternationally's Avatar
wow thats crazy good thing u cought it now
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #5 of 6 Old 06-01-2013, 09:43 AM
PlatinumDiesel's Avatar
Needle bearing from a lifter would have destroyed the lpop gyro gears and torn up the oil cooler screen then finally stopped at ipr probably tearing up HPOP. Could not have gone through oil rails via uppipes. Too many screens.
Sent from AutoGuide.com App
PlatinumDiesel is offline
post #6 of 6 Old 06-01-2013, 01:15 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It is quite possibly a piece from inside the stand-pipe. They do fail, but I don't have one in front of me to see if any parts or pieces would match.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
