changing the rail mount fuel filter... having issues - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-30-2013, 05:19 PM Thread Starter
mrc228's Avatar
Changing the rail mount fuel filter this afternoon... removed the drain plug and after about 2 gallons of diesel came out (literally) i put the plug back in.. I recently upgraded from the factory plug to the newer style and only had a little diesel come out. Is there a check valve or something that is stuck? I dont think i should have this much fuel pouring out of the drain?????
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #2 of 4 Old 05-30-2013, 05:22 PM
ZMANN's Avatar
Quoted: 1564 Post(s)
it seems to happen sometimes
try and open the fuel cap and park nose high
also some let the fuel level get a little low before changing it
We Miss you Ronnie
ZMANN is online now
post #3 of 4 Old 05-30-2013, 05:37 PM Thread Starter
mrc228's Avatar
thanks... as it turns out, tank is full and drivers side nose is low... feel kinda dumb now!
Under the hood
studs to come
In the cab
mrc228 is offline
post #4 of 4 Old 05-30-2013, 05:39 PM
ZMANN's Avatar
don't feel bad it's not written anywhere that you should do what I posted
and a slight fuel bath is normal
most guys do the upper and open the top and leave it sit open that relieves any tank pressure even though the vent should have done that IMHO
then down to the rail mounted filter
so if your just doing the lower u don't have that luxury
We Miss you Ronnie
ZMANN is online now
