2003 6.0 cuts off at idle - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-30-2013, 11:31 AM Thread Starter
hi need some help on my truck its a 2003 f250 6.0 with 74k miles on it. about a month i could start my truck and at idle it would just die it would start up again. and when i say die it cuts off like it would if you turn the key off. now it cuts off while driving. i can start it now at my house and cut off but will not start. here what i dont understand and i just noticed, if i turn the key on befor the glow plug light cut off it will start right up and run if i wait tell the light cut off like normally it will not start at all. any advice would be greatly appreciated
saleens287 is offline
post #2 of 3 Old 06-03-2013, 07:05 PM
i ve had several trucks do this and i've came to fined out that it was the ipr magnet
winds break down under heat.i replaced the ipr and problem goes away.you are losing oil pressure if that truck dies or pwr to the ficm and it's the ipr 99% of the time. when a truck shows this type of problem well at least with me let us know what you fined bud.
fatbastardf350 is offline
post #3 of 3 Old 06-04-2013, 07:18 AM Thread Starter
ok thanks so much for you info. ill check the truck out, and let you know what i find. thanks again for you reply
