puking problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-29-2013, 05:58 PM Thread Starter
puking problem
Ok have a couple questions
I have a 2005 f250 powerstroke straight pipe 4" down and out no muff no cat.
hyper pack tuner.
Just did egr cooler delete. put egr valve back in so i wouldn't get eng light. Never check if it would come on or not. Also did oil cooler at same time and replaced oil with T6 and coolant with elc. and refilled coolant to min line on bottle. i also have a sticker that ford put on the truck when the recall came out.
Ran the truck for a week 100 mile round trips 35 traffic and the rest just straight highway. and truck ran fine no coolant loss anywhere that i could see just a little bit around the top rad hose fitting. and a small drip from the filter side of the sinister coolant filter i put on.
So i put a small tune in truck and ran it for about 10 miles got into it a little bit
got home and noticed degas bottle puked. Cleaned it up and ran it on the weekend in the 90s here in florida 150 mile round trips two days in a row and no puke just noticed a small drop in coolant in degas bottle.
so do i fill to the min on bottle or the sticker ford put on.
also checked dtcs and no getting a glow plug code on number 5 but truck starts great no smoke that i can see. Shouldn't the truck miss a little at start with a bad glow plug. the code didn't come up until i tuned it, also, no dash light had to scan it once a week when i start the truck i scan for dtc codes. Do the dash lights even work in these trucks?
Any info would be great.
Thanks again.
florida250 is offline
post #2 of 3 Old 05-29-2013, 06:30 PM
PHYRMN's Avatar
The new max line is the old min line. Approximately an inch up from the front of the bottle. Also, when was the last time you changed your degas bottle cap? They get weak over time and don't hold the pressure they should.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 3 Old 05-29-2013, 07:25 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Could have been air trapped in the cooling system from your recent project allowing steam-and thus pressure-to open the cap. Very plausable within the first 10 miles.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
