2003 6.0l crank no start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-29-2013, 04:38 PM Thread Starter
Few day ago my 2003 6.0 power stroke would crank but not start. The day before the problem it started and ran fine got to work and it would crank but not start. i only have one dct that came up was a p0201. I did find that the IPR duty cycle was at 84% and only achieving 300 to 350 psi on the ICP. i could use some in sight i know there might be a leak in the HPOP or it could it be a bad IPR. Pleas any help would be a blessing.
clark325 is offline
post #2 of 11 Old 05-29-2013, 05:16 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Did you unplug ICP to see if it would start?
The earlier trucks aren't prone to HPO leaks as the later engines.
I'm thinking HPOP
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 11 Old 05-29-2013, 06:49 PM
PHYRMN's Avatar
^^^ Agreed, the only leaks that were prone to some 03's and 04's was the HPOP Discharge Tubes on some models would rub the HPOP cover and cause a leak in the tube. If your discharge tube doesnt look like this;
https://www.dropbox.com/s/vf2j7i4y3cwu7sd/Tube_2.jpg
Then I would definitely be leaning towards a weak or failed HPOP.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #4 of 11 Old 05-29-2013, 08:50 PM Thread Starter
I did try to unplug the ICP but I could get my hand back there to do that , and now I have I have the turbo FICM driver side battery and air filter and housing out of the truck. If that would prove that it's the HPOP that is at faulty then ill put back together and Try that or is there another way of test the HPOP to see if it is faulty.
clark325 is offline
post #5 of 11 Old 06-05-2013, 05:06 PM Thread Starter
Need someone help could the O-ring on the HPOP that's missing a chunk be causing my crank no start problem 2003 6.0l crank no start-imageuploadedbyag-free1370477208.002647.jpg
clark325 is offline
post #6 of 11 Old 06-05-2013, 05:54 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 274 Post(s)
Oh that is definately your problem
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #7 of 11 Old 06-05-2013, 05:55 PM
Quoted: 274 Post(s)
You should put an adrenaline pump in while your there... Huh huh
post #8 of 11 Old 06-05-2013, 08:55 PM Thread Starter
Lol I wold like to but I'm on a budget.
clark325 is offline
post #9 of 11 Old 06-06-2013, 04:34 PM
PHYRMN's Avatar
If that O-Ring is white, its the wrong o-ring on top. The o-ring that goes there is the Black D-ring O-ring. The white one goes under the pump. Here's a pic of the black "D" O-ring.
https://www.dropbox.com/s/t0pfmznjvqerpqi/Tube_1.jpg
The ford o-ring kit part number is Ford # 3C3Z-9G804-AA.
Here's a link from another site that I politely borrowed, same issue as yours.
http://www.ford-trucks.com/forums/11...03-2004-a.html
PHYRMN is offline
post #10 of 11 Old 06-07-2013, 12:05 PM Thread Starter
Thanks I bought the truck this way and I will put the right O-ring on it. The one that goes on top of the pump is the thicker O ring right.
clark325 is offline
Tags
2003 power stroke , crank no start
