HPOP problem, need advice - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-29-2013, 10:33 AM Thread Starter
Alright this is a long story so bear with me,I work on helicopters for the air force and am mechanically inclined but I do not feel like I could do this on my own. I bought a 6.0 diesel about 3 months ago, the truck ran good up until about a month ago. I took it to what i thought was a good diesel mechanic. He ran a test and said I wasnt getting enough oil pressure to my injectors, 200 psi. So he changed out the IPR, and it ran fine for two weeks. I got bad diesel and it clogged up my filters, he changed them and it idled and then died. He then ran another oil pressure test and told me it was only getting 500 psi on crank, but my fuel was fine at 55 psi. He said my HPOP was bad, and quoted me $2400, including 16 hours of labor (BULL****). I am now in the process of towing it to another shop to get it done for $1400. He told me it needs 1500 psi on crank oil pressure wise. The shop that its getting towed to is highly recommended by all my diesel buddies. The shop wants to run a $300 test by pumping 2000 psi of nitrogen to find the leak. He is saying that it might infact not be the HPOP. Do you think I need to run this test before forking out 1400 dollars for the HPOP? I would hate to spend the 300 dollars on the test and its the hpop but on the other hand i dont want to change the hpop if its not needed. I need some advice bad, i would appreciate any.
03 6.0 CCSB FX4
6" fabtech suspension lift 37" Toyo M/T's
03blackpowerstroke is offline
post #2 of 7 Old 05-29-2013, 10:52 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
The truck only needs to make 500 psi of HPO to fire the injectors at startup. Where are you located?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 7 Old 05-29-2013, 11:02 AM Thread Starter
valdosta ga, they are running diagnostics on it now. I just was going through receipts that came with the truck and the HPOP was changed out 4 months ago at a ford dealership.. So i am totally lost with this right now.
03 6.0 CCSB FX4
post #4 of 7 Old 05-29-2013, 11:09 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Chances are if it does in fact have a issue with the HPO system it is related to the ICP sensor and pigtail. Being that it is a 03, those ICP sensors would fail and leak oil into the pigtail. You should have them check that first before they do anything else. If they are bad you can use the ICP sensor from a 05-07 truck and they rarely fail. Replace that and the harness and test again.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 7 Old 05-29-2013, 04:50 PM Thread Starter
they ran the tests and found that the tubes from the HPOP were full of metal and the hpop was trashed
03 6.0 CCSB FX4
post #6 of 7 Old 05-30-2013, 01:59 PM Thread Starter
They replaced everything and truck cranks and runs good, but now they are saying that pipe for the egr delete is leaking coolant and wont seat in the intake. Another 560$ to pull off the intake and install it again. This truck is breaking me so hard I cant believe it
03 6.0 CCSB FX4
post #7 of 7 Old 05-30-2013, 02:29 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Dude fix that yourself. It's not bad and save that $560.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
