New Stand pipes and dummy plugs now it wont start - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-28-2013, 08:27 PM Thread Starter
Louiediesel's Avatar
Hi people so I replaced my dummy plugs and stand pipes with the new updated ones, now it wont start ? the only thing that I did add was put dielectrick stuff thinking it was a good a idea to water proof the FICM connectors now the freaking truck wont start need some imput/thoughts from you guys stranded in florida panhandle 6.0-350-05 Anybody knows of a mechanic in niceville/crestview area in the panhandle of florida ??
Louiediesel is offline
post #2 of 12 Old 05-28-2013, 08:43 PM
Is it turning over at all. If so try pulling the ICP wire and cranking it. If it starts then you have a bad ICP or still leaking oil. Make sure all your connectors are put back on and seated completely.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #3 of 12 Old 05-28-2013, 08:52 PM Thread Starter
It cranks over just fine ,and did the icp diconnect and it will not start, was runing this morning , in the dash gage it shows oil pressure so just confused thinking I should clean the connectors to FICM with alcohol to free them from that stuff I put in there
post #4 of 12 Old 05-28-2013, 09:08 PM
roche837's Avatar
Quoted: 5 Post(s)
Feedback Score: 4 reviews
How long have you cranked it: if you have had the HPO system open you have to reprime that system by extended cranking the truck
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #5 of 12 Old 05-28-2013, 09:12 PM
roche837's Avatar
Quoted: 5 Post(s)
03-04 trucks can take upwards of 10 extended cranks before firing
05-07 trucks is typically 3-5 extended cranks.
Dont smoke your starter by excessive long cranks
roche837 is offline
post #6 of 12 Old 05-28-2013, 09:19 PM Thread Starter
well been doing about 5 or 6 long cranks and nothing..... wont fired up will try it again in the morning still want and going to clean that stuff I put in the FICM connectors? got this gut feeling I should it left along !!
post #7 of 12 Old 05-28-2013, 09:24 PM
roche837's Avatar
Quoted: 5 Post(s)
wouldnt hurt, get a scanner on it and see if your FICM is synced while cranking, wheck your fuel bowl, filling with fuel? oil gauge coming up on dash? get some sleep and retry tomorrow sometimes thats always best. Good Luck let me know how you make out
roche837 is offline
post #8 of 12 Old 05-28-2013, 09:32 PM Thread Starter
yes showing oil building up in the dash gauge will tackle agin the morning, burned out with it tonight
post #9 of 12 Old 05-29-2013, 08:28 AM Thread Starter
still not having luck, getting fuel ok,not sure about anything if going on with the FICM dont have a way to test it with at a friend garage with limited tools, the only next thing to do is take the drivers side dummy plug and stand pipe and put the old ones back in there ,the pasenger side did had a bad O ring and it fired up when I replaced that side, but not with the drivers side?? at a lost any ideas will be more than welcome and appreciated. !!! But if is getting readings in the dash gauge that means the new parts are good, but then at the same time I been fool before by new parts.?!!
post #10 of 12 Old 05-29-2013, 05:11 PM
roche837's Avatar
Quoted: 5 Post(s)
Have you replaced the STC fitting? Double check the O rings on the dummy and stands
roche837 is offline
