6.0l starter issue - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By twoicebergs
post #1 of 4 Old 05-28-2013, 12:03 AM Thread Starter
05F350Lariat's Avatar
6.0l starter issue
So do to a few different factors my truck has sat for a little longer than I had anticipated. Recently I went out and got the truck ready to start but when I turned the key all I heard was the starter spinning up but not engaging. I've had this problem before on 302 v8's and usually a couple blows from a hammer while your trying to start it will get the starter to engage, no such luck with my truck however. So I'm assuming I need to pull the starter. Or is there some trick I'm not aware of? If I do pull it is there something I can try or am I in need of a new starter? Also if it does come down to a bad starter I've heard I should steer clear of aftermarket units. Any truth to this? And does anyone know the best deal on a new starter?
2005 F350 Lariat CC LB 4x4
SCT Livewire with EGT Probe, IDP FICM Programmer, 175/30 Renegade Diesel Injectors, ARP Head Studs, EGR Delete, STC Fitting Upgrade, Turbo Oil Feed/Return Line Upgrade, Blue Spring Kit, BullyDog CAI, Accufab Intake, FS2500 Oil Bypass Filter, Coolant Bypass Filter, Mean Green HO Alt., IDP Long Y Pipe, MBRP 5" SS Turbo Back Exhaust.
05F350Lariat is offline
post #2 of 4 Old 05-28-2013, 04:07 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
This guy's starters are first rate. I have one and would recommend them to anyone. $85
Ford 6 0L Diesel Starter 2003 2010 | eBay
tastebud likes this.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 4 Old 05-28-2013, 05:01 PM Thread Starter
How long have you been running with that starter?
post #4 of 4 Old 05-29-2013, 05:11 AM
Quoted: 46 Post(s)
7 months so far. It is a well built unit.
Frank
Working for Toys
