EBP READING 0 PSI when not running and 2 PSI AT IDLE? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-26-2013, 02:53 PM Thread Starter
my edge insight is saying my EBP Is 0 when the engines off and 2-3 at idle. I though it should be roughly the same as barometric and MAP. Is this an edge insight issue or is the sensor bad? I do get a bucking when pulling hills and sometimes on flate freeway.
Ndekens is offline
post #2 of 16 Old 05-26-2013, 03:46 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Whats your baro sensor reading at idle?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 16 Old 05-26-2013, 03:50 PM Thread Starter
It's about 14.9. Map is 14.
Ndekens is offline
post #4 of 16 Old 05-26-2013, 04:03 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
EGR intact?
Whose tuning
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 16 Old 05-26-2013, 04:04 PM Thread Starter
Originally Posted by Dave View Post
EGR intact?
Whose tuning
Yes truck is a bone stock 2003 excursion with no tunes.
Ndekens is offline
post #6 of 16 Old 05-26-2013, 04:06 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Theres your answer.
Trucks with EGR intact will almost always show a few PSI of EBP. Its needed for EGR flow
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 16 Old 05-26-2013, 04:08 PM Thread Starter
Theres your answer.
So does that mean it is working correctly? I'm a ford newbie! Thanks for the help!
Ndekens is offline
post #8 of 16 Old 05-26-2013, 04:29 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Yup
Turbo vanes might be a bit sticky though
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 16 Old 05-26-2013, 05:21 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Depending on the buid date of your truck... If your truck is pre 9/29/03 and has the updated inferred 06E17 strategy in the PCM, the EBP sensor is no longer used. The EBP is "inferred" through MAF, MAP, BARO, and EOT. Check your build date
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #10 of 16 Old 05-26-2013, 05:25 PM
Quoted: 275 Post(s)
However, at idle, with no load, and the VGT DC at 60-75%, the EBP should be 12-20psi
