puking issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-26-2013, 11:59 AM Thread Starter
puking issue
Ok, I was holding back on posting this because i believe it is the head gasket but have a garage telling me no way. I was burping out of the degas bottle all the time going up steep hills and running at 80mph, so I ran my temps and had a 40 degree difference between the oil and coolant. I ended up changing the oil cooler, deleting the egr, flushing the coolant system and adding a coolant filteration system. I also installed a new degas bottle and cap and a new thermostat. Before changing everything I took it to a mechanic and he performed a die test on the truck finding no mono gases. After the job was done the truck ran great for a week. I put a small load of stone on it and it starting puking again. My coolant has been running at 195 and Oil at 198-204after the work. I do notice that my coolant hoses are extremely hot. I cant even touch them. I took the beast back to the garage and they did another die test to find nothing. I am convinced its a head gasket which i dont want it to be. At one point after driving I went to remove the degas bottle cap and there was so much pressure it blew off. The garage tried to tell me there is air getting in the system probably from the coolant filter. I have a small leak out of the thermostat housing and its hose that I havent done anything with yet. Can that be an indication of anything. Would like some feed back. Thanks
tb9555 is offline
post #2 of 3 Old 05-27-2013, 03:21 AM
follow bill's advice on checking the cooling system pressure to see if its the head gasket's.
So hook up a pressure gauge (0-30 PSI) hook it into the upper degas bottle hose thats closest to the drivers side(3/8's hose) then run the hose out from under the hood and tape it to the windshield, go for a drive and find a hill then come on to it in 3ed gear and watch the pressure if it jumps up really fast and starts burping around 17-18 psi, your head gaskets are gone, but how your explaining things, its your headgaskets is my guess
Good luck! make sure you have a GOOD quality shop replace the head gaskets one that uses a torque wrench as often as they can! and the head's be checked at the best machine shop in town DONT risk anything! the extra money to have a quality job done is 100% worth it!
Ive done 2 sets of ehad gaskets on 6.0 trucks done tons of other repairs on them mostly oil coolers but whenever i do ANY job no matter what engine it is, everything has to be spotless taking the extra time to clean stuff is ALWAYS worth it!
mebob2001 is offline
post #3 of 3 Old 05-27-2013, 07:59 AM
steelnc's Avatar
Take I to a different shop. It definitely sounds like the Hg's.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
