Slightly low ICP when warm - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-25-2013, 10:35 PM Thread Starter
twoicebergs's Avatar
Quoted: 46 Post(s)
This may take a while before it is easy to diagnose.
A few months ago I put in a new set of larger injectors. It ran very strong right out of the gate until the day I dynoed my truck about 3 weeks ago. Go figure... Outside of problems with loading the dyno that day, the truck seemed to run OK, but not quite as strong as normal. It seemed to have a slight miss about 1800rpm driving at 65mph. It only put down about 440hp and 770lb-ft and I attributed the lower drive pressure and ICP to the dyno loading. I later thought it was an injector harness connection, but today when I loaded Wildman's Extreme, this is what it did. Just after a cold start I pulled out of the yard the truck was running very strong and with little pedal the ICP was easy to get to 4000+ psi, almost too easy! However, after I was up to 65 mph, there was a definite miss as it was warming up, almost like stiction, but only at about 1800 rpm. All other parameters: FICM, EBP, MAP, Fuel Pressure, EGT, ICP and IPR were normal. After reaching normal operating temp there was no miss, but it took more pedal than normal to get the typical acceleration. The ICP would not go above 3000psi with the IPR commanding 82% at WOT.
I loaded the stock tune and a medium power tune and the ICP did reach 4000psi with the lower PW.
When I did the buzz and contribution tests (AE) cold it tested normal and did not miss. I will try to get a sample at 1800rpm cold tomorrow under slight load and see if the miss resurfaces.
My thoughts are I may have an injector to rail seal, standpipe, dummy plug STC leak or weak IPR, but they all looked very healthy when I put the injectors in (STC or IPR were not inspected). Of course, it could still be the HPOP. It has the original IPR, STC, HPOP, standpipes and dummy plugs. Yes I will replace the stand-pipes and dummy plugs for the updated ones during the next injector change in the next week or 2. I will also inspect or change IPR if it seems questionable. The STC will probably be changed out when I upgrade or pull the turbo.
My question is, "Can I get reliable air pressure test results with such a low pressure drop, or am I going to have to wait for more deterioration?"
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #2 of 7 Old 05-26-2013, 06:44 AM
04cr450's Avatar
In my experience- my truck was doing the same nagging thing your truck is doing.. Did all tests and could not find anything.... I believe I did not have a leak but a faulty IPR valve. When I did my injectors, new turbo and other upgrades- I updated the dummy and standpipes, icp , and the big one which I think was the problem, The IPR valve. Truck runs very smooth and quiet, almost to smooth sometimes lol anyways I would replace the IPR. Just going off of how my truck reacted to this.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 7 Old 05-26-2013, 07:10 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I've been in a few trucks that had hot tunes and ICP never did reach 4000psi like they would with lower tunes. Isn't this a characteristic of the tune?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 7 Old 05-26-2013, 07:20 AM Thread Starter
Quoted: 46 Post(s)
So I took it out for a drive and did another balance test under load and it was pretty much flat across the board, even in the slight shake rpm. I varied the load via braking and no cylinders were off. The IPR never made it past 82.49%. Unfortunately it looks like AE can't read true voltage or pressure of the ICP with a tune on. As before, as the temp gets above 180, the shake is pretty much gone. I am just about to try stock for a road test of the ICP/IPR and then maybe reload the tune from my computer to the SCT and again on the truck. Who knows, maybe the tune took a dump in the SCT.
My Dashboss can read real volts and pressure with any tune.
Update: Stock tune (with larger injectors)
No miss or vibration. ICP got to 3800 with slight varying between 3500-3800 at WOT. Boost max was 26.4 psi.
As I said, I will re-reload the tune and see what happens. I'll report back later. Time to take the boat out... water temp is still in the high 40s - low 50s, still ice on one lake near hear... don't know if we will break out the surf-board.
Frank
Working for Toys
post #5 of 7 Old 05-26-2013, 07:39 AM
This is very difficult to find. Air pressure will not be helpful imho. If I was going to guess I would say stc if you have the old style.
First thing to do would be to verify that the actual icp and the desired icp do not match.
cfd_shop is offline
post #6 of 7 Old 05-26-2013, 05:56 PM Thread Starter
Quoted: 46 Post(s)
Water temp was 50*F...
I reloaded the file and it is running better, but the ICP remains lower than it had been. Perhaps with the Max PW tune and the 75% nozzles it can't keep up. However, when it was cold up here it the tune always ran stronger, including more injection advance. With the extra 2 or 3* in the lower RPM, it really had more get up and go.
As a check, I loaded 3 more custom files and all let me get 85% IPR with 3500-4000 psi ICP. None of these files had PWs in excess of 2.0ms. So I remain stumped as to why it seemed to miss, but did not show up on the diagnostic runs. This leads me to believe it may have been a system issues like perhaps an IPR sticking or fluctuating. If it comes back or I notice something when I change out the injectors I will post back. I hate intermittent problems!
Frank
Working for Toys
post #7 of 7 Old 06-18-2013, 09:22 PM Thread Starter
Quoted: 46 Post(s)
Update.
Since the last post I put in the 190/50 injectors, updated to the new stand-pipes and dummy plugs with no real change in the ICP. The truck will get 4,000 psi on a lower PW tune, but on a Max PW tune it tends to end up about 3,100 psi when warm. Today I tried the IDP Extreme and it gives full IPR and it did give 4,000 psi until the oil temp got over about 170*. So, something is off, or I need to use thicker oil! The performance remains very good, but it would be better with full ICP. I still should update the STC and try my new IPR valve, but I will wait until I update the intake manifold.
update this evening
Pressure is 2500... Looks like I'll be diving in for some work and maybe a new pump very soon.
Frank
Working for Toys
