911 Need help with bolt turbocharger - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-25-2013, 10:44 AM Thread Starter
chris-rector's Avatar
Okay I'm in the process of changing my HPOP got to the point where I'm trying to take out my turbo charger however the rear bolt that holds and seems to have been stripped by the mechanic that I took to last time I was on the road in Texas the bolt is in really tight any suggestions on getting it out help 911
<a href="http://truckprofile.com/members/chris-rector/Ford-F350-2003/694">My Truck Profile</a>
chris-rector is offline
post #2 of 7 Old 05-25-2013, 10:51 AM
Quoted: 2 Post(s)
If you have another vehicle go to Lowe's and pick up an Irwin stripped bolt remover socket set. Comes in a 3-4 pack for different sizes and work wonders
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #3 of 7 Old 05-25-2013, 10:52 AM
06Lariat_'s Avatar
If you can get a socket that is just too small for it and hit it on the bolt. Also use a 6 point not a 12 point. This can work sometimes. If its really tight/sized on with rust use some heat or penetrating oil first. Hope it works
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #4 of 7 Old 05-25-2013, 11:20 AM
rdaffin's Avatar
Use pb blaster on it. Just a.? Are you using the right size socket or wrench (10mm). I'm sure you are just have to ask. If it is a cheap socket grind down the opening until the flats are flush with the end of the socket. I'm doing my oil cooler (for the 2nd time) right now.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #5 of 7 Old 05-26-2013, 11:47 PM Thread Starter
Yeah I'm using a 10 millimeter Craftsman tools just not budging man soaked in PB Blaster
Thank you for the people that have reply to this post I swear by PB Blaster been using it for years and as for the strength to tools they work great at it out no time flat I appreciate your help I love this forum
post #6 of 7 Old 05-27-2013, 02:10 AM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
i would also second the erwin bolt out kit, mine werent stripped but i would use this in your situation
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #7 of 7 Old 05-27-2013, 06:53 AM
You might try the CRC or Loctite freeze penetrating oil aerosols.
Welcome to: LoctiteŽ Freeze & Release
http://www.amazon.com/CRC-05222-Freeze-Off-Super-Penetrant/dp/B000KKCQUW
Wobbly is offline
